Kofi Annan in: "Kofi's Baby Huey"
Old 11th September 2010, 03:43 PM   #101
jkeny is offline jkeny  Ireland
Banned
Life's a bitch in the world of DIY, sometimes, isn't it - sorry I can't help you with this one!
Old 11th September 2010, 03:48 PM   #102
adamus is offline adamus  United Kingdom
vacuum cleaner?
Old 12th September 2010, 01:02 PM   #103
Soonerorlater is offline Soonerorlater  United Kingdom
Soonerorlater's Avatar
Shake'n'vac
Old 12th September 2010, 01:16 PM   #104
SGregory is offline SGregory  United States
Kofi,
Once you can see clear again, just pull the enbells off carefully and retireve the wayward clipping. Then do with it what you want.
Living Life Doing the Waltz in 4/4 meter.
Old 29th December 2010, 06:25 PM   #105
bigjppop is offline bigjppop  United States
Just wanted to bounce this one up to the top and see how it all came together; any more pictures to show off?
Old 1st January 2011, 02:29 PM   #106
Kofi Annan is offline Kofi Annan  United States
Kofi Annan's Avatar
OK-- here's an update. I was so emotionally damaged from the piece of wire that wound up in the tranny that I put the project down for a while, then got snowed under with work.
I did take the bell ends off, but I never found the bit of wire. Unless it's seriously jammed in there, I think it must have bounced back out when I was fiddling with it.
Anyway, the tranny is back together and I mounted the rest of the components. Thanks to the reminder post from bigjppop, I'll resume the project today.
Pictures to follow.
Kofi
Old 1st January 2011, 02:34 PM   #107
Kofi Annan's Avatar
Fuzzy and grainy but, as promised, a photo.
Old 5th March 2011, 02:10 AM   #108
Kofi Annan's Avatar
Standard Kofi wiring technique, here. Admonish with avant-garde haiku, as below (5-7-5):
snakes approach the pole
worried
from
----- e
----n
---t
--a
---n
-----g
lement
hum and hiss prevail
Damn, Kofi. That is some deep motherfather ****.
e.e. kofi
Old 5th March 2011, 06:09 AM   #109
mackinthebox is offline mackinthebox  United States
lookin good
question, are those new JJ Tesla tubes?
Ive been pondering buying a set of the new JJ Tesla tubes for a 6v6 amp im building and I am wondering what your opinion is on their sound quality...
Old 11th March 2011, 06:58 PM   #110
Kofi Annan's Avatar
I've always liked the JJ tubes, but I'm not really an expert. I've never had one fail and I think they sound great. Price is right as well...
So, I hooked up the amp last weekend and I was popping fuses all over the place. I noticed that I had some reverse continuity in one of the PSU diodes, so I rebuilt the supply with new diodes. Upon starting up this morning, I saw the B+ rise to about 390VDC and then the 1A fuse popped. I tried a 2A just to see if the inrush was killing it, but it popped right away without the B+ rise the second time.
I think I'll disconnect the supply and test it standalone. Any ideas on a resistor value that would be good for testing the supply? Any ideas on what may be causing this?
Kofi
Kofi Annan in: "Kofi's Baby Huey"Hide this!Advertise here!
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 05:19 PM
Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" Kofi Annan Tubes / Valves 135 15th October 2007 06:15 AM
Kofi Annan in: "300beee!" or "Kofi Gets a Toy" Kofi Annan Tubes / Valves 125 25th August 2006 03:39 AM
