diyAudio Sponsor
Old 29th April 2010, 02:26 PM   #1
Default "The Sussex Homebrew Valve Tester"
Has anyone heard of/or seen "The "Sussex Homebrew Valve Tester" ? This looks like a really great project ! I would be very interested in others thoughts or opinions about this. It can be found by doing a simple google search ect...
Old 29th April 2010, 05:07 PM   #2
Ty_Bower's Avatar
I found the link, but you need to be a forum member to download the images and schematics. There's quite a lengthy thread there.
Old 29th April 2010, 05:11 PM   #3
Here is all the info, but you have to be member to download or see.
The "Sussex" Homebrew Valve Tester. - UK Vintage Radio Repair and Restoration Discussion Forum
Old 29th April 2010, 05:20 PM   #4
Default Schematic
Valve tester2 circuit
Old 29th April 2010, 06:14 PM   #5
Soonerorlater's Avatar
Valve tester2 circuit.zip
PDF file too big so I zipped it
Old 29th April 2010, 06:25 PM   #6
Default Here is another link
Give this a look ! Hope it works > http://homepage.ntlworld.com/lez/Sus...nstruction.JPG
Old 29th April 2010, 07:37 PM   #7
Default Here is the pcb
Old 1st May 2010, 12:30 AM   #8
Hi-Q is offline Hi-Q  England
Hi-Q's Avatar
Quite a few being built in the UK, my latest circuit is on the link below where I have added a low heater voltage regulator for testing battery valves and a heat sink fan.
Also combined the whole circuit together, I think it is better to download the image and view in MS Paint.
Still in the process of metal bashing. You only have to 'free' register on the Forum to get full access to it.
Les
http://homepage.ntlworld.com/lez/Sus...truction_4.JPG
Notice I added a 50 way D connector to the PCB for easy servicing and the circuit shows the pins I chose for the various functions and signal paths.
Old 1st May 2010, 10:14 AM   #9
Hi-Q's Avatar
Also may I add that I believe the circuit boards and transformers are still available from the Forum members responsible for having them manufactured. The transformers can be supplied with primary voltage for the States. Note that the custom transformer has three separate and thus isolated meter supply outputs for powering the low cost AC powered LCD panel meters as mentioned on the Forum.
Old 2nd May 2010, 12:47 PM   #10
Hi-Q, Has there been any revisions made to the pcb layout to facilitate changes ? If so could you post a picture ? I have ordered a transformer but decided to wait on the pcb till all mods or additions are final.
Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area baileyler Swap Meet 0 14th January 2009 02:07 PM
"El Cheapo Valve Phono" using 6ER5=>12AT7WC? fred76 Tubes / Valves 20 20th October 2008 03:48 PM
ZA members: Death of Wim "Mr Valve" Bouwman Steerpike Everything Else 5 11th July 2008 10:05 AM
John Linsley Hood "Valve and Xstor" amps jackinnj Swap Meet 0 4th July 2002 02:14 AM
Book for FS "Build your own Audio Valve Amplifiers by Rainer Zur Linde (English)" zobsky Swap Meet 0 5th April 2002 05:18 PM
Page generated in 0.10197 seconds (76.08% PHP - 23.92% MySQL) with 11 queries
