diyAudio Sponsor
Old 27th April 2010, 12:42 PM   #1
losacco is offline losacco  United States
Default Eliminating volume pot?
I'm thinking of eliminating the 100k volume pot on this schematic but not sure what I need to change.
Old 27th April 2010, 12:52 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Is this a guitar amp? or designed for normal audio listening?
You can remove the pot by placing a resistor from grid to ground, then you are driving the grid directly. Not the best design. Options are add a small (10K series resistor on the input, or add a coupling cap.
What are the tubes?
Your gain going to be pretty high with the second stage cathode bypass. I'd be inclined to leave the gain pot in place.
Others are more familiar with DHTs and such stages and may have more insight.
Old 27th April 2010, 12:53 PM   #3
Tubie Noobie
replace it with a 100k resistor to ground. I would consider a small grid stopper of about 1k though.
Gimp makes some valid points as well.
Living Life Doing the Waltz in 4/4 meter.
Old 27th April 2010, 01:08 PM   #4
Also, is that a pot I see under the output tube...?!
http://blog.liammartin.com
Old 27th April 2010, 02:57 PM   #5
DougL is offline DougL  United States
That is a common hum null pot for DHT.
I second the 100k resistor plus grid stopper.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 27th April 2010, 04:12 PM   #6
Doug,
To quash the hum from the AC heaters? Apologies, never looked at DHT before.
L
Old 27th April 2010, 04:14 PM   #7
A Walton Audio design. Tubes are 5692 and 300b. I have finished one mono block. I use my computer to play mp3 and have noticed little volume increase and poor clarity from the computer source. Basically I turn volume up 100% and I get poor gain and sound quality. When I use my line stage/preamp, things sound great.
Old 27th April 2010, 04:41 PM   #8
Tubie Noobie
Not sure that replacing the volume pot with a resistor will correct the above issue.
Old 28th April 2010, 02:57 AM   #9
I don't know what computer/sound card you are using, but my Mac Mini audio output is about 1/3 the level of a typical CD player (mine also suffers from induced noise from the big LCD display, a common problem afflicting Mini's).
Either way, you are not going to solve the level problem by removing the volume pot unless the computer's expected load impedance is way higher than the pot value.
Ooh! Just had a thought! If you don't have a coupling capacitor on the amp input before the vol control, maybe the computer has some DC on the output line (and your preamp doesn't). It wouldn't take much DC getting to the amp's first stage grid to really mess things up.
Old 28th April 2010, 03:35 PM   #10
alexg is offline alexg  Philippines
alexg's Avatar
Is that Walton design or Joseph Esmilla's? Can't remember now.
volume pot william1981 Solid State 5 25th February 2007 10:31 PM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Changing Volume Pot 9am53 Solid State 1 8th December 2005 07:29 PM
Gain pot instead of volume pot boyofwax Solid State 5 14th February 2004 02:37 AM
New Volume Pot lilolee Parts 7 3rd August 2001 11:43 PM
Page generated in 0.10531 seconds (76.67% PHP - 23.33% MySQL) with 11 queries
