tube dual regulated psu needs amp tube dual regulated psu needs amp - diyAudio
Old 27th April 2010, 12:43 AM   #1
ohill is offline ohill  United States
Default tube dual regulated psu needs amp
I have this psu that I think puts out 18V and wondering what I could build to put this to use. Like maybe a preamp, amp, turntable, headphone amp???
It's a verdier and was made to use with their control "B" preamp.
What they say about it:
"That power supply totally electronically regulated, includes 3 tubes, 1 rectifier 5Y3 provides the direct current to the regulation device constituted by a low internal impedance tetrode 6Y6 working with a sharp cut off pentode EF 184 which issues the amplification of the error signal."
DualPwer
I would like to eventually build a 45, 845, 2A3 or 300B amp and was wondering if this would be good to use for anything as an already made PSU.
BTW it's the 115V 60HZ U.S. model.
What do you think it would be best suited for?
thanks
rob
Old 27th April 2010, 04:32 PM   #2
kevinkr's Avatar
Just wondering how it came to be separated from its pre-amp counterpart.. Rather odd to say the least. Somewhere out there is a Control B missing its supply, and it would probably be worth having both. The pre-amp and supply retail new for over $2K. Before doing anything I would contact J.C Verdier to make sure it is not stolen, and then in the event that it is not they could probably provide a schematic and some specs.
I would be surprised if this supply could deliver enough current for anything other than a very small mono SE. You might power a pretty hefty stereo line stage however.. It's not going to be useful for much else IMHO. This supply provides filament voltages and a high voltage (possibly as high or higher than 300V) for plate power in the tube pre-amp it was meant to power.
The electrolytics in it appear to be 15yrs old and may need replacement.
http://jcverdiervalvevinyl.online.fr.../ControlB.html
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th April 2010, 07:02 PM   #3
Thanks!
Yes I have emailed the company already with the serial # and am yet to hear back from them. Not sure how it got separated from it's counterpart. Wish I had it.
Anyway, I'm not going to do anything just yet till I hear back from the company with schematics hopefully.
voltages are:
High voltage output 320V-30mA
Low voltage output 18V-0A6
It's the 115V U.S. model
"You might power a pretty hefty stereo line stage"
Tell me more. Could you point me in a direction for a line stage project that this may power?
I'll update the post if I hear anything back from the company.
rob
Old 27th April 2010, 07:18 PM   #4
"The electrolytics in it appear to be 15yrs old and may need replacement."
I think this unit is only about 5 years old. I could be wrong or maybe they built it with old caps?
Old 27th April 2010, 10:32 PM   #5
kevinkr's Avatar
It's possible that what looks to me like a date code on the top of those caps in fact isn't, but the serial # information should answer that question pretty well.
I'm thinking a cool line stage you could power off of this supply would incorporate a pair of 6J5 driving plate to line transformers or perhaps an SRPP or similar. Note that some mods to the supply are likely required. The 600mA at 18V is the issue as Verdier obviously connected the pre-amp tube filaments in series parallel as those are 6.3/12.6V filament types in the Control B.
Old 27th April 2010, 10:57 PM   #6
OK, Thank you!
I think this is all probably way over my head. I will wait on the schematics and see where to go from there.
Thanks for taking the time to reply to my post.
Very nice gear on your site. I plan to go back there soon and check it all out in detail.
Take care and I'll let you know if/when I get a reply from Verdier.
Rob
Old 28th April 2010, 12:06 AM   #7
rotaspec is offline rotaspec  New Zealand
Looks like it would be a suitable supply for an Aikido line stage running 12AX7/12AU7 tubes. Regulate the 18v down to 12.6v for the heaters using a 7812 regulator IC with a diode in its earth leg to get the extra 0.6v if needed. However 600ma is going to right on the limit for 4 tubes in stereo.
Printed Circuit Boards and Kits
Old 28th April 2010, 04:06 PM   #8
Thanks!
The company Verdier emailed me this today.
The DRPS provides with
2 voltages: 1 : 18 Volts for the tubes filaments
2 : + B Voltage for the electronic circuits
NB : The voltage + B is not critical .
It is very easy to adjust it with the little potentiometer which is on the PCB.
I recommand you 280 Volts.
(my unit is U.S. model 115v so not sure if all above apply)
tube dual regulated psu needs ampHide this!Advertise here!
Verdier dual regulated tube psu ohill Tubes / Valves 2 27th April 2010 11:02 PM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 10:45 PM
Multiple purpose dual regulated psu cviller Power Supplies 13 26th February 2008 06:03 AM
Simplest Tube Regulated PSU? pftrvlr Tubes / Valves 3 1st August 2007 11:35 AM
Regulated psu for tube preamp wuffer Tubes / Valves 21 15th October 2005 05:22 AM
Copyright ©1999-2017 diyAudio
