diyAudio Sponsor
Old 25th April 2010, 07:06 PM   #1
jt1 is offline jt1  United States
Default Hammond P-T125E OPT
I am considering this OPT to use for experimenting with various SE and PP amp designs . It is advertised as a "universal" for both SE/PP with a wide range of I/O impedance's. Is this suitable for my needs, and will it sound comparable to "dedicated" SE or PP OPT's, or is there another I should be looking at?
jt
Old 25th April 2010, 07:51 PM   #2
The 125E is strictly push/pull. Look at Hammond's writeup. For SE, the 125ESE is what you need.
Both the 125 and 125SE series are NOT intended for HIFI service. Considerable derating is necessary to get reasonable bass extension. The 125ESE could be OK with a triode wired 6V6 or a 2A3, as the O/P tube.
Eli D.
Old 25th April 2010, 08:08 PM   #3
el156 is offline el156  Portugal
el156's Avatar
Default Hammond OPTs
Hi !
I sugest the P-T1608A to begin with a El84 PP Ultralinear, And the P-T1627SEA for single ended EL34 , those are intended for HI-FI use !
And the quality is good for the price!
GOAHEAD!
hammond transformers? ipop07 Tubes / Valves 21 14th June 2011 03:00 AM
Tubelab Simple SE OPT Query (Hammond 1628SE vs 1629SE) Junior Tubelab 13 25th December 2009 11:30 PM
Hammond or James OPT for SE 300B ? ashok Tubes / Valves 30 12th December 2009 04:13 PM
Hammond Gripe kmaier Tubes / Valves 94 4th June 2009 07:07 PM
Page generated in 0.07982 seconds (68.93% PHP - 31.07% MySQL) with 10 queries
