| diyAudio Sponsor | ||
I'm trying to come up with PCB mount tube socket for a Russian IV-12 VFD tube.
It's a 10-pin miniature, in the same circle as a 9-pin miniature (12mm pin dia.) but with closer pin spacing (32.7 degrees vs 36 degrees) ![]() I tried some Mill-Max PCB pin receptacles. Best is 0312 but non-stocked and $0.89 per pin = $8.90 a socket. The 0314 is great but the collar shorts to adjacent pins. Not sure who else makes receptacles. Someone else ripped pins out of cheapo plastic 9 pin sockets and used them. Any ideas? |
#2 |
Ohms Law V = I R |
#3 | |
Valve & Nixie Socket Calculator to calculate the positions of the PCB pads when I make a Protel footprint for the component. M |
#4 |
Thanks, I checked again and I had the wrong dimensions in my original post.
No luck finding PCB mount 10-pin miniature sockets. There are at least three Euro types: B10A, B10B, B10C, 10C12 bases, so it is confusing. The Decal B10C base - 10 pin, 1.02mm (0.040") dia. pins, 11.9mm (0.469"), 34° pin spacing, gap 54° - matches the IV-12, 6X9, ECF200, PCF200 etc. It's similar to Russian РШ23 (RSH23) or the B9A 9-pin base. There are some ceramic solder lug ones from China on Ebay, but no PCB mount. I found Euro tube socket info here: Pentodensockel - Pentode Bases |
#5 | |
Otherwise, it's the (expensive) machined contact pins Mill-Max 0314 or Keystone micro-jack #1414 would work for tube sockets. |
#6 |
Yep, they are just regular solder bucket cheapies, sorry don't have a specific part number - 25 pin sockets for around a buck seems a good deal!.
| Tube Sockets | FaxMeBeer | Tubes / Valves | 5 | 7th February 2010 09:31 PM |
| FS oddball tube amp for parts | woody | Swap Meet | 5 | 13th May 2007 10:39 PM |
| I need miniatures lamps # 1869D | gaetan8888 | Parts | 0 | 9th May 2007 10:28 PM |
| tube sockets | bigpanda | Tubes / Valves | 1 | 15th June 2006 09:34 PM |
| Tube sockets with the same pin spacing as the tube | Andypairo | Tubes / Valves | 5 | 15th March 2004 01:08 AM |
| Page generated in 0.11039 seconds (78.82% PHP - 21.18% MySQL) with 11 queries |
