diyAudio Sponsor
Old 24th April 2010, 02:01 PM   #1
skid20 is offline skid20  United States
Default Bogen chb35a
I was looking at the schematic for my bogen chb35a and was wondering if anyone could shed some light on why there is 240/260v going to the cathodes on V2 (12ax7)?
Would anyone have an idea what this voltage is being used for in this amp?
I would like to do some modification after I get it back up and running.. just finished changing the electrolytics and have a hammond 1620 on the way to replace the burt OT..
It just that this is different from anything I have seen (yet) and I would like to understand it a little better if possible lol
Old 24th April 2010, 03:29 PM   #2
rsumperl's Avatar
Greetings,
The 220K and 470 ohm resistor form a voltage divider. The voltage at the cathode will be +.55 volts. They use it for biasing the tube.
Ray
Old 24th April 2010, 03:35 PM   #3
Originally Posted by rsumperl View Post
Greetings,
Ray
Thanks Ray, that makes more sense to me now
Old 25th April 2010, 02:14 AM   #4
Another question I have been struggling with is would it be safe to feed the output of V1a into the grid of V1b as to utilize both stages at once?
I assume that running the output on V1a into the grid of V2b would also mean I would be removing the .1uf cap that is present at the grid currently...
Am I on the right page here or is this going to cause trouble?
Old 25th April 2010, 04:52 AM   #5
lol I meant V1b into V1a... not thinking while typing = garbled nonsense!
Old 25th April 2010, 06:26 AM   #6
That would give you way too much gain. Why do you want to do this?
Old 25th April 2010, 12:35 PM   #7
I'll be using it for guitar eventually, I guess I'm just going for one input more than anything. Would it make more sense to wire a switch between the to halves of the triode on a single input to change from one to the other?
Making it switchable sounds like a better idea to me in terms of guitar use.
If I set it up a three way switch that runs V1a or V1b or both (via one feeding the other or parallel) would there be a way to manipulate the gain in my favor?
Old 26th April 2010, 01:59 AM   #8
Old 26th April 2010, 07:00 AM   #9
I just don't get what you want to do. What's wrong with the amplifier as is?
Old 26th April 2010, 12:23 PM   #10
Its not a guitar amp. I intend on modifying it to be so. I'm just looking for a single input that is switchable between "channels" if you will..
Bogen MX60A whitelabrat Swap Meet 1 18th July 2011 10:55 PM
Bogen CHB35a Problem skid20 Tubes / Valves 1 28th August 2010 04:09 AM
Bogen MX60a blindbrett Tubes / Valves 4 16th September 2007 02:34 PM
Bogen amp bobhedberg Tubes / Valves 1 20th May 2006 09:29 PM
Bogen help sickss Tubes / Valves 0 2nd June 2004 01:25 PM
Page generated in 0.09977 seconds (75.74% PHP - 24.26% MySQL) with 11 queries
