Phono preamp with c/em2
Old 23rd April 2010, 09:00 PM   #1
el156 is offline el156  Portugal
el156's Avatar
Default Phono preamp with c/em2
HI !
I was looking to some of my old tubes and i found a few C/EM2 from Telefunken,and i had a crazy idea of making a phono preamp with them using the triode section of this very old magic eye! but i dont know if this triode has enough gain to do the job ! I did not find this data in the web!
Maybe someone could give me a help! what is the gain of this triode?
Thanks !
Old 23rd April 2010, 09:46 PM   #2
Arnulf is offline Arnulf  Europe
datasheet
It doesn't look nearly as bad as I would have guessed from its intended role.
It has mu of 50 and I'd really be interested to hear how it sounds with CCS load. Others will chime in regarding phono portion of your idea, I never dealt with those before.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 24th April 2010, 09:45 AM   #3
el156's Avatar
Originally Posted by Arnulf View Post
datasheet
Thanks!
I have made a few tests and this triode seems to be very linear! Making a phono preamp with this tube, we also have a VU METER! How about that?i
When i finish this project,i will send report with photos and test results!
Thank you!
Old 24th April 2010, 10:20 AM   #4
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Obrigado.
If you can see the speaker cone move...it's not hifi.
Old 24th April 2010, 11:37 AM   #5
Excellent. I suggest you have a look at the tube phono preamp article mentioned in most recent DIYaudio newsletter. Author elaborates really well on all aspects of development, I read the article through in first ago even though I don't own a single record and mostlikely never will have any need to play them (interesting explanation is provided on the subject of noise in high amplification factor circuits). Here's the link:
http://www.diyaudio.com/forums/diyau...no-preamp.html
Phono preamp with c/em2Hide this!Advertise here!
Phono Preamp bayermar Tubes / Valves 51 18th November 2009 04:04 AM
About a phono preamp gaetan8888 Analogue Source 13 16th November 2009 04:51 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Phono preamp Burnedfingers Tubes / Valves 14 16th June 2006 01:14 PM
