Schematic help!
Schematic help!
Old 16th June 2003, 11:11 PM   #1
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Question Schematic help!
In the image below, what is the purpose of the circled bit? It is the preamp section of an 807 PP amp, and uses a direct coupled EF37 to 6SN7.
It is a bit hard to see, but there is a 220uF in series with a 12.5K resistor which goes from the grid of the 6SN7 to ground.
This is taken from http://hollowstate.netfirms.com/DIY_files/proto.htm
which is a great site and has a lot of interesting stuff on it.
Thanks!
Old 16th June 2003, 11:47 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
It sets the HF limit of the earlier stages. In practice it probably reduces ringing. The cap will most likely be 220pF BTW.
Old 17th June 2003, 01:46 AM   #3
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
it shunts the HF to ground.
wiht a value like 220pf, its quite high freq.. like radio, not audio...
Old 17th June 2003, 03:23 AM   #4
DSummer is offline DSummer  United States
100% sure it's 220pF, you can find this kind of design in most vintage amps....
DSummer
Old 17th June 2003, 05:23 AM   #5
SHiFTY's Avatar
Thanks, I was thinking it was some kind of attenuator to reduce the frequency response, and 220uF made no sense at all...
Oh well, on to the build stage I guess!
Old 17th June 2003, 06:11 AM   #6
tubetvr is offline tubetvr
Hi
Does this amplifier have global feedback? The reason I ask is that these kind of RC networks is sometimes used as phase compensation in feedback amplifiers in order to increase phase margin and reduce risk of oscillation, the RC network will reduce the phase shift at higher frequencies and therefore make the amplifier more stable, I use this kind of compensation in some of my amplifier designs.
If it is indeed used for this purpose I advice against removing it as it will increase risk of oscillation.
Regards Hans
Schematic help!Hide this!Advertise here!
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 05:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 03:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 08:30 PM
