diyAudio Sponsor
Old 21st April 2010, 01:11 PM   #1
Default Grid Bias or Cathode Bias
Hi Again
I have searched threads and am wondering pros and cons of grid biasing a PSE of 6550s vs Cathode Biasing. My Understanding is that grid leak resistors change in either setup as do coupling caps. You also have a bit more freedom with b+ in that you have more available in grid bias scenario but the thought of Bias supply voltage failure sounds scary Can anyone recommend a circuit/implementation (Bias winding from transformer or voltage divider from b+) for grid bias that can be adjusted and a good operating point for two 6550's in a pse configuration.
Does one sound different to the other?
Many thanks
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 21st April 2010, 01:57 PM   #2
el156 is offline el156  Portugal
el156's Avatar
Originally Posted by duderduderini View Post
Hi Again
Many thanks
Nick
HI !
I think if you prefer grid biasing and to make sure it doesnt fail, you must add in serial with the tube supply, a fuse of about 160ma/tube. But i prefer cathode bias,wich makes an automatic ajustment of tube current. I tested both and didnt notice a big difference in sound quality, and i always use a decoupling capacitor in paralell with cathode resistor to avoid feedback,because it sounds better without it!
But it is only my opinion! some people think different!
Good Luck
Old 21st April 2010, 11:56 PM   #3
When you get beyond the needs of "12" W. types and 7591s, cathode bias can become problematic due to I2R heating in the cathode resistor.
A well sized (wattage wise) 10 Ω metal film resistor under each cathode, when employing "fixed" bias, serves both as an "idle" current test point and a fuse. If the bias supply fails, the resistor burns out, before tube damage occurs.
An interesting option that has much (IMO) going for it is combination bias. Stand the cathode on an unbypassed 100 Ω resistor and apply a negative voltage to the control grid. The cathode resistor provides a convenient test point, part of the total bias voltage, stabilizes the operating point, and provides a small amount of distortion control via degeneration (local current NFB).
Eli D.
Old 22nd April 2010, 03:01 AM   #4
+1. "Mixed bias" gets a bad rep from certain CBS-era Fender amps, but done properly, it should allow more stability without sacrificing very much power. Depending on how you size the cathode resistors, you get a little "tube balancing" in the deal, too.
- Scott
Old 25th April 2010, 11:59 AM   #5
Default Whats the most reliable methode of providing bisa voltage
Hi Eli
Thanks for the replies ( i mean to thank all of you)
I see a lot of different ways to supply the bias voltage. transformer tap, suitably rectified etc... lm317 with lots of components (that could fail?). Where could i look to find as bulletproof a design for grid biasing (along with partial cathode biasing)
Thanks again to all of you
Old 25th April 2010, 12:30 PM   #6
chrish is offline chrish  Australia
chrish's Avatar
The power amp schematics at AX84 have grid bias with the power supply taken from the B+ with a very simple circuit. Look here at one of the PP amp to see AX84.com - The Cooperative Tube Guitar Amp Project
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
How to get cathode bias info from grid bias info? leadbelly Tubes / Valves 8 14th August 2008 04:40 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Page generated in 0.09576 seconds (75.85% PHP - 24.15% MySQL) with 10 queries
