diyAudio Sponsor
Old 19th April 2010, 07:26 PM   #1
Default Help With Left Channel Hum
Hi.
After enjoying some sonically significant upgrades to a Cary SLA 70A Signature EL-34 P-P amp which includes a complete re-tube, new filter caps, coupling caps and cathode bypass caps I'm dissapointed that a low level hum still exists in the left channel. Although you have to place your ear close to the speaker to hear it, I'm somewhat surprised that the issue wasn't resolved along with the recent component changes. The right channel is dead quiet, btw.
I've attached a schematic but need to warn you I am somewhat of a novice when it comes to utilizing them. Any advice would be welcome. Thanks.
Old 19th April 2010, 07:28 PM   #2
bigwill is offline bigwill  United Kingdom
Does it go away with only one channel connected from the preamp?
Old 19th April 2010, 07:32 PM   #3
No, and forgot to mention that. It is originating somewhere in the power amp.
Old 19th April 2010, 11:14 PM   #4
The resistor in the filament wiring is marked SELECT so maybe you need to change that one. That's the one at the bottom of the diagram.
Else you may have a heater-cathode leakage on the 6SL7; did you swap them?
If the two channels are operating from separate power supplies perhaps one supply is not properly filtered; look at the 500V electrolytic capacitors.
Are the two units wired identically? You could have a ground loop injecting hum into the amplifier input.
Old 21st April 2010, 10:24 AM   #5
Both the inverters and filter caps are new. All the tubes have been replaced.
Left channel dead doubled Solid State 10 11th April 2010 11:19 AM
Can I have the sub woofer channel and the left and right channel as one? Boscoe Chip Amps 7 21st February 2010 05:56 PM
Hum in left channer - rogers cadet 3 cr0wl3y Tubes / Valves 6 7th January 2010 11:44 PM
Hum left channel on Threshold SA3 (I know its not a pass labs but...) Tino Pass Labs 3 30th May 2008 02:53 PM
Need help with hum and faint left channel on my S5 Electronics kit Neville Tubes / Valves 4 15th January 2007 10:58 PM
Page generated in 0.08563 seconds (73.21% PHP - 26.79% MySQL) with 11 queries
