line pre amp
line pre amp
Old 31st January 2002, 06:08 PM   #11
phil is offline phil
Hi Bernhard
Thanks for your reply. Yes I can that the ecc81 is not a favourite so I will use perhaps your suggestion. What type of transformer is it?
Phil.
Old 5th February 2002, 06:59 AM   #12
dice45 is offline dice45  Germany
Phil,
the preamp i am currently using is a borrowed one, but as i know meanwhile, it is on AudioNote level or better; my friend Manfred lend it to me until my own differential PP preamp gets ready. So i had to ask him for specifics.
Manfred's preamp has an input selsector and a 50kOhm ladder attenuator at the input. From that the 5687's grid is fed. The tube runs at 25 mA quiescent current. The used trannie is a Simon Shilton / SJS model PA102; it has a turns ratio of 5:1 and an impedance ratio of 15kOhm to 600 Ohm.
Warning, the trannie is slightly uncheap, but AFA i can tell, it is worth it.
At the moment, SJS has one pair of them on sale for UK-Pounds 85 a piece with chrome-plated shrouds. The normal retail price is at UKP 115, TMK. Recently, a British line preamp was reviewed in a German high-end audio magazine, Manfred reported, and the unit had a retail price of about US$ 9000.
With this simple structure, you are launched directly to orbit
Run and order as long as the sale trannies are available.
Bernhard
line pre ampHide this!Advertise here!
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 02:20 PM
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 27th January 2009 12:44 AM
Peerless V-line XT line woofer discontinued first_1st Multi-Way 1 12th August 2008 05:55 PM
Line output as line input transformer? bambadoo Tubes / Valves 7 22nd January 2008 07:44 AM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 10th March 2005 12:35 AM
Copyright ©1999-2017 diyAudio
