Just finished building an RH84 which sounds great, but I get noise from the pot in the middle of its range. The amp is nice and quiet with the control in the min. or max. position but anywhere inbetween produces a not very loud, but annoyingly noticeable type of crackling/rustling sound. Any ideas as to what this could be. I built exactly as per shematic.
Charles
Charles
That sounds strange... the circuit I'm looking at is here,
RH 84 - Tube Audio ...... RH DESIGN
so I'm assuming you have connected the pot wiper "direct" to the grid.
What happens if you replace the pot with two fixed resistors ? equal to the "setting" of the pot in circuit.
What happens if you AC couple the pot?
Stereo... two channels ? Are they both the same ?
My input:
Get contact cleaner ans spray it in the pot and turn it a few times. IF that does not solve you problem I am willing to bet lots of rands (ZAR) that it's somewhere else in the circuit. Some ground issue.
probably of no use:
I had a problem once when designing a filter circuit for an amp. The amp was a test unit with no input DC blocker cap. The Op amp circuit that I was designing had a design error where the input audio had no ground reference. Things worked fine for some reason , but as soon as you touch the pot on the amp it sounded like rustling of leaves en speaker moved in and out vigorously.
probably of no use:
Hi guys,
Yes the pot. wiper connects to the grid stopper resistor 330 ohms which is soldered on a very short lead to the grid.
I don't think its caused by a dirty or faulty pot. because as I approach min. or max. the problem completely dissappears. I tried some switch cleaner and rotated the knob PLENTY. The noise is at its worst from about the 9 to 3 o'clock position.
I retouched all solder joints with no change. The amp is dead quiet otherwise.
Charles
Charles
Hi Mooly,
I have not tried replacing the pot. with fixed resistors as I don't believe it to be the problem. Its new and the problem is common to both channels.
What I failed to mention is the 'scope shows assymetrical clipping on both channels with the top of the wave clipping gracefully, but the bottom looks terrible with a sharp lower edge and then a convex curve before becoming a sine wave again.
Hi Mooly,
I Think you need a decoupling capacitor in the input of the amp ,because you may have some DC present in
the input! Test 1MF/100V!
good luck
- Tubes / Valves
- Volume pot has rustling sound
