diyAudio Sponsor
Old 18th April 2010, 03:57 PM   #1
Default 6as7 SE OTL
Hey everybody,
I have i speaker 10 Wrms/8 Ohm 94 db/W/m in a backloaded horn type enclosure so,
I want to built an amplifier with 6AS7 OutputTLess about 10 Wrms/8 Ohm or more,Single Ended,
I found lot of schematics but without info about out power or Zout
Heeeeelp
Old 18th April 2010, 06:01 PM   #2
Ok I think about this one but Push Pull
6AS7GA OTL
who knows if works that machine?Any idea?THD=?
Αt 8 Ohms watts=?THD here?
Old 18th April 2010, 09:59 PM   #3
Miles Prower's Avatar
The only way you're going to accomplish this is with Bench's inverted VT topology. Here, here, and here.
Any way you try this is going to require a whole bunch of 6AS7s. VTs just aren't designed to operate as high current, low voltage devices.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 18th April 2010, 11:16 PM   #4
kevinkr's Avatar
Hey everybody,
Heeeeelp
I have seen a number of Japanese designs using choke loaded 6AS7 cathode follower SE output stages, but they are both extremely inefficient and have rather high output impedances - in most cases I would expect more than 20 ohms, and this makes global NFB mandatory IMHO.
A single pair of 6C33 in a futterman style configuration will net you about 20Wrms and an output Z of perhaps 10 - 15 ohms making global NFB a good idea. The Rosenblit 6AS7 based OTL design might be a good place to start. (You could convert to 6C33 if you are ambitious.)
The 6C33 can be an amazing performer in OTL applications and could also be used in an SE OTL if you wanted, a single tube might get you a few watts.
That said I abandoned OTL amps (I was a fan of the circlotron configuration) for DHT SE amplifiers about 12yrs ago, and would recommend this route to anyone with efficient speakers.
I'm not a fan of "inverted operation" and not a big fan of the Futterman either, but it can work quite decently.
www.kta-hifi.net
Old 22nd April 2010, 06:35 PM   #5
I think that i will build this one
Does anyone knows any change ??
Old 22nd April 2010, 09:09 PM   #6
atmasphere's Avatar
This whole thing has been covered on this thread:
What tubes for a tube amp?
Scroll down and you will see the schematic.
I have high efficiency speakers too. The fact of the matter is that if you use the setup as seen in the thread, you will be able to use the least amount of tubes possible of any OTL design. With an upside down SE design you will need more power tubes and make less power, with more distortion. Its really not worth it.
I have a tiny pair of amps I use that have just one 6AS7G per channel. You would think that there would be all sorts of problems but they work quite well. My preamp has a similar circuit in it that uses 6SN7s and it can drive the loudspeakers (16 ohms) to a moderate volume as well, with great bass response.
You could also run one pair of 6C33s, a single 6336 or even a pair of 7241s. Each has their strengths and weaknesses.
Old 23rd April 2010, 01:38 PM   #7
1)Ok then NO SE..
2)Can you show us these schematics(6AS7G)&(6SN7)?To run a 8Ohm speaker what i need?
Old 23rd April 2010, 07:51 PM   #8
Any sound or load deference between this , this , and this one?what are the Advantages and disadvantages for each one?
Rozenblit 6as7 otl questions Klimon Tubes / Valves 15 30th January 2011 11:03 AM
Futterman style 6AS7 OTL with other tubes Brit01 Tubes / Valves 39 22nd July 2009 05:04 PM
6as7/6080 Se Otl desperateaudio Tubes / Valves 103 6th January 2009 01:19 PM
6AS7 OTL croccodillo Tubes / Valves 14 16th August 2007 11:14 AM
6AS7 OTL mr l Tubes / Valves 7 8th March 2007 01:36 AM
Page generated in 0.10450 seconds (89.49% PHP - 10.51% MySQL) with 10 queries
