12b4a phase splitter! The best?
Old 15th April 2010, 10:37 AM   #1
el156 is offline el156  Portugal
el156's Avatar
Default 12b4a phase splitter! The best?
Hello everibody
I am working in my latest amp and testing phase splitters to find up the best sounding one!
The output is EL34 ultralinear PP and tested 12At7,12Au7,12aX7 as phase splitters, but i found in my old box 2 12B4A tubes, and connected them with 9K resistor cathod to ground,9K plate to B 300V and grid to previous tube plate (12At7) with 100V plate voltage! And i found i have the best sound i ever had!
Does someone tested this tube (12B4A) as phase splitter?
If not TEST IT because it sounds raelly NICE!
Best Regards!
Old 15th April 2010, 01:20 PM   #2
andyjevans is offline andyjevans  United Kingdom
This is a concertina you are talking about?
Old 15th April 2010, 01:53 PM   #3
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
Running a pair as LTP in a linestage. B+ near 500, 20k plate loads, CCS tail and plate voltage ~125. Very nice performance and balanced output to drive a Rane crossover. tried also triode-strapped EL86 with similar results, slight edge to the 12B4. Quite sensitive to vibration picked up from the top plate from the power supply Iron. Going to fix it with a separate plate for the amplifier section and some damper rings like herbies tube dampers.
cheers,
Douglas
the Tnuctipun will return
Old 15th April 2010, 03:21 PM   #4
el156's Avatar
Yes, concertina or i thik is also called cathodyne ! I only have 3 12B4A and would like to buy some more ! If someone has some to sell ,i am interested in some!
THANKS (Obrigado)
Old 15th April 2010, 03:47 PM   #5
Palustris is offline Palustris  United States
Palustris's Avatar
That makes sense as with a concertina (split load) you want a tube with low mu (there is no gain with this stage anyway) and high transconductance. The 12AT7 and 12AX7 would be eliminated right away as unsuitable given the requirements. If you like the 12B4 then try the 6S4. Even better try the 6EM7 with the high mu as the voltage amp and the low mu as the phase splitter.
Old 15th April 2010, 09:03 PM   #6
radiostar is offline radiostar  Yugoslavia
ECC40 is also interesting, simply adore that tube specially like phase splitter!
tubes.rs
12b4a phase splitter! The best?Hide this!Advertise here!
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
phase splitter with Tr ? sam8888ysl Tubes / Valves 9 22nd October 2008 11:28 AM
Help diagnosing phase-splitter pilli Tubes / Valves 13 5th July 2008 02:53 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 09:48 AM
phase splitter question stoo Tubes / Valves 3 2nd November 2005 03:46 AM
