adding line out to guitar tube preamp - Page 3 - diyAudio
Old 16th April 2010, 06:19 PM   #21
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Decrease pot's value and try again. Say, take 50K instead of 500K. Or use an audio taper pot instead of linear taper one.
The Devil is not so terrible as his math model is!
Old 17th April 2010, 01:11 AM   #22
I would suggest you to take direct output from the 1'st opamp (buffer) instead of from input.
I supose that you talk about the OUTPUT of the first opamp. Just between the two 680K resistors?
Well, I have try and try and the only way I was able to do it with a DPDT is by connecting it where the input was (See attachment No4).
There is a ground problem when the effect is off. I don't know where to connect the ground. I don't even know if this is possible.
The other option I have inspected concern the use of a 3PDT switch (See attachment No5).
Thanks for the advice about the pot. It is already a log pot in fact. I'll try a smaller value.
Old 17th April 2010, 01:26 AM   #23
Wavebourn's Avatar
Ouch, I see the problem now: do you really have 100 pF cap across the pot?
Short it.
The ground should be always connected.
Old 17th April 2010, 01:43 AM   #24
Ok.
Could you tell me in which way is this cap affecting the behavior of the pot? It is not all clear to me.
What about the 3PDT schema?
Old 17th April 2010, 02:36 AM   #25
As a side comment, you don't need the capacitor in series with the transformer primary. That line already is blocked from DC.
Old 17th April 2010, 07:44 PM   #26
Thanks to all of you.
I removed the LT cap and the cap connected in serie with the gain pot.
Here is the result.
So it is getting better and better but I feel a bit frustrated regarding the reasons of thoses mods (specially regarding the behavior of the 100 pF cap).
I was also wondering how this schema would work with a +12 volt instead of the actual +9V (seems to be a good way to improve the behavior of this effect)?
Old 17th April 2010, 10:55 PM   #27
What you have should work, except when the unit is OUT you may not have enough level from the line out, which should be more than 1/2 Volt. You are taking what I believe is an instrument pickup and trying to get line out level, not possible. You need some gain.
As for raising the voltage to 12 Volts, well I assume the 9 Volts is to get some clipping; thus you will have to go to a higher level before clipping occurs.
I am so used to trying to make amplifiers do a clean job that I find it hard to work with anyone who deliberately wants distortion. Music sounds so much better undistorted, I think.
Old 18th April 2010, 12:41 AM   #28
Thanks bob for your point of vue.
I know this polemic on distortion is on the grill since decades. If you look at the recording history, lots of famous records takes there succes in the fact that the tape rec or the amplifiers creates 'natural' distortion. It was a smooth and nice disto, nothing to do with the overcompressed, overdistortioned sound that we can actually hear. Think about the old blues records from Chicago or Mississipi, the round and fat sound they produced, this is my field of inverstigation.
Well, that's also something I am scared off. When off, the volume 'll drop down. What if I connect after the second opamp? After the 0.1 F cap instead of between the two 680K resistors?
P.S. :I am using a electric guitar as input (single coil)
Well, this is not a bad news. This way, it 'll probably behave much more closer to want I want. I'll give it a try soon ('ll buy iron and other stuffs next week).
Old 18th April 2010, 12:57 AM   #29
Ian444 is offline Ian444  Australia
hacaira,
You may find you already have 12V going into the circuit, as I can't see how 9V will power the tube filaments.
How about this plan - leave the pedal as it is. Make a new box and use that NE5532 you have to build a preamp/buffer for recording. Then you can switch your pedal on or off as you please and use the pedal's volume control to match clean and "dirty" levels. The preamp/buffer circuit would only cost a few dollars in caps and resistors. You could power it with a 9V battery, or share the other supply.
Ian
Old 18th April 2010, 01:32 AM   #30
For a line out, just add an opamp. You don't even need a transformer unless you have to have isolation. Figure out how much signal you have from the pickup and it will tell you the gain you need. Of course, you sacrifice the variable gain into the line out, but you could use the control on the guitar, which would affect all outputs.
I just built a guitar amplifier and now am going to add a microphone input. I am deciding whether to add an external passive mixing box, sort of a Y thing with a volume control, to take the two inputs, or add an opamp just for the microphone (I already have that inside the amplifier, currently using only two out of a quad chip).
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
tube preamp: adding headphone out then_dude Headphone Systems 10 19th July 2012 12:02 PM
Looking for tube guitar preamp high-fi Tubes / Valves 10 24th May 2006 03:27 PM
Multi-purpose tube amp (line and guitar inputs) smsmonster Tubes / Valves 28 20th May 2006 01:12 AM
Guitar Tube Preamp Kaiowas Tubes / Valves 5 24th April 2004 11:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
