#11 | |
EDCOR - GXSE5-8-5.5K They're decently sized transformers; certainly more beefy than some I've seen scavenged from vintage consoles. Sure, they're not even going to begin to compete with transformers from Mike LaFevre or Jack Elliano. Hashimoto and Tamura aren't worried either. Still, these are some solid transformers at prices that shouldn't be overlooked by the novice. The photo shows them with a pair of noval tubes and sockets for size comparison. ![]() http://i69.photobucket.com/albums/i4...E/P1130289.jpg Last edited by Ty_Bower; 10th April 2010 at 02:33 AM. |
#12 |
Why not start with this guy?
RH 84 - Tube Audio ...... RH DESIGN It is a proven design and if you use an OPT with UL taps you can even try running UL with and without the plate to plate FB.
If We The People refuse to hear the truth we will be ruled by liars. |
#13 |
Exactly. The OP circuit just looks broken. Best avoided.
Ears aren't microphones. |
#14 |
You could also build a Spud. Three tubes for a stereo amp. I think the total tube cost was $15-ish. $40 for output transformers (Edcor XSE-8-5K), and I think about $30 for the Antek power transformer.
Sounds pretty good. ~Tom |
#15 | |
#16 |
yes. i built that amp already. sounds very good. i use it for netflix and the computer. i changed the tubes to 2 6v6 and 1 6sl7. i like it. its not going to fill an auditorium, but it fills the living room nicely. about 5 watts per. using old university coax 12 in speakers.
| All Tube Stereo power amplifier | Dusk | Tubes / Valves | 11 | 18th September 2006 11:51 AM |
| WTB: smaller beginner level Tube Amp | askforbes | Swap Meet | 6 | 11th June 2006 02:13 AM |
| Two Stereo Tube Amps Into Monoblocks | artclone | Tubes / Valves | 3 | 22nd March 2006 07:39 PM |
| Beginner , tube kit suggestions please | bryank89 | Tubes / Valves | 5 | 28th February 2005 04:33 AM |
| Tube kit for beginner | mlihl | Tubes / Valves | 3 | 11th November 2004 06:12 PM |
