diyAudio Sponsor
Old 9th April 2010, 08:46 PM   #1
Default 6AU6 and 6J5 for Guitar amp or pedal?
I'm itching to get my feet wet with some tubes.
I got a single 6AU6 and a single 6J5, can I bulid a small amp or distortion pedal with these components?
I have seen similar projects with different tubes. I am look ing to take the edge of my big SS amp or even build a small tube amp.
Can I get any distortion out of a setup like this.
If you think it's plausible I should be able to fiqure it out from there.
Thanks!
Old 9th April 2010, 09:59 PM   #2
nigelwright7557's Avatar
A much cheaper and simpler alternative is a soft limiter which bascially gives valve overdrive type distortion.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 10th April 2010, 12:04 AM   #3
Arnulf is offline Arnulf  Europe
By all means: jump in !
You can definitely get distortion out of any active element. Tubes are active elements
I'm not into guitar amplifiers so I'm not sure where to head from this point but in "normal" audio I'd place the pentode at the input, followed by the tone stack, and ultimately by cathode follower using that triode. If you need more gain, change cathode follower into regular common cathode stage. If you want distortion, bias that triode way off-center.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 10th April 2010, 03:05 AM   #4
Awesome, that's what I wanted to hear. I might actually be able to slap something together.
I have a few parts I've been hanging on to from an old Scott Dynaural Hifi.
This sounds like fun.
6AU6 and 6J5 for Guitar amp or pedal. TechnoBeaver Instruments and Amps 1 15th April 2010 08:13 PM
Need help with guitar tube pedal schematic. el rockyo Instruments and Amps 4 23rd February 2009 09:13 PM
6J5 and 6F6 SE - enough gain for guitar? PRNDL Tubes / Valves 10 20th September 2007 08:16 AM
Curious how to put a volume pedal between tube guitar amp head and speakers of same. nova62400 Instruments and Amps 11 30th May 2006 09:03 PM
Guitar Pedal Glowin Plates Instruments and Amps 7 9th March 2005 05:16 AM
Page generated in 0.07114 seconds (73.00% PHP - 27.00% MySQL) with 10 queries
