diyAudio Sponsor
Old 8th April 2010, 09:34 PM   #1
phrarod is offline phrarod  United States
Default Need help changing 12V heater to 6V
I want to use a different tube that uses a 6.3V filament. I have a 12.6V supply but the reg is adjustable.
What resistor changes ie values do I need for the resistor divider network that is in there now. It has a 200R and a 2K. Schematic attached.
Much appreciated!
Old 8th April 2010, 10:02 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
The regulator is an LM317T (made by National Semiconductors and many others). You can calculate the resistors needed for a given output voltage by following the equation on pages 1 and 9 of the LM317 data sheet.
~Tom
Old 8th April 2010, 10:22 PM   #3
Thanks Tom! My math is horrible but I give it a go since the formula is there. I have values in there as reference for calculation for 12.8V
Old 8th April 2010, 11:02 PM   #4
Gorgomat's Avatar
LM 317 Calculator
Old 8th April 2010, 11:12 PM   #5
I dont know what current you need? but be sure you dont run the 317 too hot
Cheers Matt.
Old 8th April 2010, 11:41 PM   #6
WOW! The calculator is awesome. Looks like R2 or in my case R11 is 810R I get 6.3V
I don't think it will run too hot.
Old 9th April 2010, 12:52 AM   #7
Banned
How much current?
If the tube is equivalent, then the current will be ~double that in the original circuit. The voltage dropped across the 317 will be 6.3 volts higher. So the dissipation in the 317 will be ~4 times the original.
Has it got a heatsink? 400% could be too much...
w
Old 9th April 2010, 01:22 AM   #8
It does have a heat sink. I need to investigate this. Thanks for the reality check on this.
Old 9th April 2010, 03:08 AM   #9
I was using a 5965 and will be moving to a tube with the following specs:
Uf = 6.3V, If = 350 mA uM = 25 Ia = 10.5 mA S = 6.8 mA/V Pa = 1.5 W
I have two filament supplies. One for each tube.
Old 9th April 2010, 05:22 AM   #10
One last question. If I do run into heat issues with the reg can I go to a LM335T and have the same voltage divider resistor values?
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
12.6v+ vs 6.3v+/- heater supply mountainhick Tubes / Valves 16 28th February 2010 03:41 PM
Again (sorry) what's the biggest 6V heater double rectifier? leadbelly Tubes / Valves 5 8th August 2007 11:24 PM
12v to (6v times 2) legendaryfrog Parts 8 27th October 2006 09:34 PM
Using 6V to power 12V DAC Ian J Digital Source 0 4th January 2004 06:18 PM
Page generated in 0.11231 seconds (76.95% PHP - 23.05% MySQL) with 11 queries
