diyAudio Sponsor
Old 8th April 2010, 08:35 AM   #1
Default Sustitute 5842 for EC86
I am planning a Phono Preamp using the 5842 tube. However, these tubes seems quite costly and I am considering replacing them for EC86 that I have available and are less expensive. Is that a good idea, and would that require a major redesign of the schematics?
Old 8th April 2010, 09:06 AM   #2
revintage's Avatar
Hej Hans,
The EC86 is a very good tube in RIAAs if you donīt get problems with microphony. The tubes does not have very much in common.
An option could be to use the EC86 as input tube and parallell the the two halves of a E88CC( or 6N6P=lower gain/lower Zout) at the output. Personally I find the EQ a little nweird but it will anyway work. But almost all component-values has to be changed.
Brgds
Lars
Old 8th April 2010, 09:42 PM   #3
Thanks, The obvious is the ampl factor (u=68 for ec86 and 43 for 5842) and that would have to be lowered in circuit (?) The EQ network would have to be altered as well?
Any other suitable replacement tube for 5842 (aside from the 417)?
Old 9th April 2010, 05:26 AM   #4
revintage's Avatar
Gain difference is only just above 4dB so no big deal. If you donīt want more total gain you can go for something like 6N6P in the second stage itīs got 6dB lower gain. With E88CC second, total gain will be almost on par.
But still, whatever tube you go for componentvalues have to be altered. Or letīs say the complete circuit should be redsigned.
There are no easy to find substitutes to find for 5842. 6c45 comes to mind but seems hard to get nowadays.
Brgds
Lars
Old 13th April 2010, 06:03 PM   #5
Thanks for your input, I understand that the schematics needs reworking and right now I am not in the position to do that. However- someone who has experience ( and a schematics) for a RIAA phono amplifier that would fit the EC86 tube? As I understand it , the tube would qualify very well as a base for a highquality phonoamp.
Regards/ Hans
Old 13th April 2010, 08:48 PM   #6
db! is offline db!  Canada
I have used the 6S3P-EV and 6S3P-DR as a cheap substitute for the 5842. Keep in mind that the max anode voltage is slightly lower than the 5842 and/or the WE417. Also keep in mind that the pinouts are not the same...
Old 14th April 2010, 09:56 PM   #7
Some confusion here, The 6S3P-EV seems to be listed as 6S3P-EV/EC86/PC86 tube at Tubes-Store.com - Vacuum tubes, capacitors, nixie, sockets. Wholesale & retail trade. Worldwide shipping. The 6S3P-DR might be an option. I am aware of the pinout and will change them accordingly.
Thank you all for your valuable information. /Hans
Old 14th April 2010, 11:08 PM   #8
R.I.P.
The WE417/5842 is MICROPHONIC to a degree that in a mic pre you don't need to bother with a microphone!
A far better tube for phono prte is the Russki 6C45, or 6P45 if you like. Even more gM that the 417, far more consistant and much less microphonoc. In current production, and costs less than most NOS tubes.
But I don't understand the reson for the half passive, half active RIAA eq. Doing the active that way is VERY noisy because of the very high impedances seen at the grid of the second tube.
Regards, Allen
Old 21st April 2010, 07:48 PM   #9
I wonīt argue about that, the designer has identified himself, and the schematics is from AudioXpress Jan 2010.
Russki 6C45, or 6P45 if you like: Do you mean the
cyrillic C (S) or P (R)? In that case the tubes are not identical?
Old 21st April 2010, 08:35 PM   #10
R.I.P.
No idea. Maybe 6S45. Made by Reflecta, sold by Electroharmonix. I mean the single 9 pin triode with a gM of circa 45mA/V.
Regards, Allen
EC86 and phono Hojvaelde Tubes / Valves 1 3rd April 2008 05:08 PM
5842 and 5842 WA for 300B massi68 Tubes / Valves 11 18th January 2007 10:41 PM
Ec86 Tekko Tubes / Valves 6 8th June 2005 03:14 AM
Can a DCX2496 be a sustitute for Orions x'over?nt Lito Digital Line Level 31 26th January 2004 02:48 AM
Kls-9 Woofer Sustitute dinamic1 Multi-Way 0 13th March 2002 09:29 AM
Page generated in 0.15340 seconds (82.68% PHP - 17.32% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
