Did tone bypass on PAS what about caps
Old 7th April 2010, 10:04 PM   #1
lduncan is offline lduncan  United States
Default Did tone bypass on PAS what about caps
I was thinking of just replacing all the caps in case I ever wanted to return it to stock. But if I only replace the caps being used do I just do the ones on the phono board or are there others I should replace.
Old 8th April 2010, 01:17 PM   #2
Pyre is offline Pyre  Canada
Pyre's Avatar
Send a message via MSN to Pyre
Have you got a copy of the schematic?
I have found the best plan of action if you ever want to return it to stock is buy 2 new boards for 20 bucks of ebay and install all new components. Ignore the LS section and the FS section parts. Bypass the tone section and ignore all the components from that section as well. A lot of very useful pdf's can be found here:
Dynaco-Doctor.Com - Dynaco Parts, Repairs, Restorations, Premium Modification
Old 8th April 2010, 06:33 PM   #3
indianajo is offline indianajo  United States
indianajo's Avatar
Default caps in PAS preamp
Of course you replace the electrolytic capacitors in a PAS every 20 years. However, my 1961 PAS2 has gotten uneven in gain between the channels, and the resistors test okay, so I am going to replace the paper caps. I've got some film .02 and .05 uf 400 VDC caps from newark, 10 % tolerance, and not being a Pay-pal addict nor a fan of auctions, I'll be repairing my original boards. I'm going to leave the mica caps alone, or whatever those 750 pf ones are, presuming that to be less sensitive to moisture-air than paper dielectric.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Did tone bypass on PAS what about capsHide this!Advertise here!
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
Dynaco PAS Preamp Tone Controls Justin_122 Tubes / Valves 0 7th October 2007 04:32 AM
bypass tone controls on heathkit sp-2 Rispoli Tubes / Valves 5 17th May 2006 01:01 AM
Bypass caps on crossover caps... :D quickshift Multi-Way 19 27th November 2005 12:59 PM
Tone ctrl bypass reduces volume? DragonMaster Solid State 17 9th September 2005 02:10 AM
Copyright ©1999-2017 diyAudio
