How to evaluate RF tubes for power and fidelity?
Old 7th April 2010, 04:07 AM   #1
thadman is offline thadman  United States
Default How to evaluate RF tubes for power and fidelity?
I'm interested in purchasing a quantity of Russian military surplus vacuum tubes for an amplitude modulated 27Mhz RF amplifier. How can I evaluate the power and fidelity (linearity) of the tubes or differentiate between them? I'd prefer a minimum of 1kW. However, 10kW would be best.
Here is a list of Russian military surplus vacuum tubes that are available for broadcast.
STC NavigatoR / Tubes / Broadcast
If you are familiar with any of the models, I would greatly appreciate a recommendation.
Thanks,
Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 7th April 2010, 04:52 AM   #2
bob91343 is offline bob91343  United States
It's patently illegal to do what you are planning.
Old 7th April 2010, 08:33 AM   #3
Arnulf is offline Arnulf  Europe
He wants to create a tube-driven plasma tweeter.
@thadman: tubes capable of handing such high power will require forced colling, usually water colling. No if, no buts, anode voltage in kilovost range + plumbing to get water to the anode coupled with lack of experience is a recipe for disaster. Needless to say the power supply would have to be enormous (and expensive).
You were given a link to a project that different people have completed. Why not complete that first before setting out to do something as outlandish as multi kW tweeter (what's the point of that anyway - to run a concert ?).
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 7th April 2010, 10:01 AM   #4
tubesteve is offline tubesteve  China
tubesteve's Avatar
Location: since 1998 in China as an electronic consulting design and testing engineer
Default RF tubes
my best advice: if you already ask how to evaluate these tubes, then best is for you: keep the fingers of that, besides the legal problems.
The amount of humans is increasing, but the amount of available intelligence remains a constant.
Old 7th April 2010, 10:15 AM   #5
danzup is offline danzup  Romania
danzup's Avatar
Thanks,
Thadman
By constructing and see how it is working ???
There are not better tube than 6P3S and 6N2P for my ears !
Old 7th April 2010, 06:55 PM   #6
Could you expand on this?
Old 7th April 2010, 07:05 PM   #7
Arnulf,
It was previously suggested to use an adjustable gap. An Air-Core transformer could be used to step-up the voltage to the required levels for a 15cm gap (225kV/electrode). I'm concerned I won't be able to maintain the "holding current" required for a stable plasma with such high voltages.
Correct me if I'm wrong, but 225kV @ 1kW = .004 amps
Old 7th April 2010, 07:09 PM   #8
My error; I thought you were building a transmitter.
In any case, watch out for unwanted radiation or you could get into trouble with FCC. Worse, an army of angry CB operators may descend on your place.
The Russian tubes appear to be good. Many hams use them with good results. What types are you considering?
Old 7th April 2010, 07:46 PM   #9
kavermei is offline kavermei  Belgium
kavermei's Avatar
Send a message via MSN to kavermei
It's not easy to make a transformer (air core or other) that will handle 225kV... arcs will fly all over the secondary, punching holes in the insulation of the windings...
Never send a human to do a machine's job. --Agent Smith
Old 7th April 2010, 07:57 PM   #10
jrenkin is offline jrenkin  United States
A long time ago, when I worked in lasers, we had a 50KV transformer made for an experiment we were performing. We had to submerge it in insulating oil and the power wire coming out of it, insulated in one inch of silicone would have blue fingers of electricity radiating from it. Arcing was frequent to anything else. You couldn't point your finger at it from less than a couple of feet. The l;ab smelled of ozone. It is amazing we survived. Truly these voltages need to be in well controlled environments and most home work areas just wouldn't be safe.
How to evaluate RF tubes for power and fidelity?Hide this!Advertise here!
Musical Fidelity X10-D - changing tubes problem gsrai Tubes / Valves 17 30th March 2013 10:14 PM
Bunch of NOS Sweep/RF/Output tubes FS GordonW Swap Meet 0 2nd June 2008 02:36 PM
Near RF/audio tubes east electronics Swap Meet 3 25th November 2007 04:14 PM
Got some tubes, help me properly evaluate them Andypairo Tubes / Valves 8 31st October 2004 09:13 AM
IEC power filter- EMI/RF- for power amp biff584 Solid State 9 22nd October 2002 07:29 AM
