Lil' Devil P-P Amp
Lil' Devil P-P Amp
Old 28th April 2010, 12:10 AM   #11
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by OneyedK View Post
I don't see the high gain in the driver/phasesplitter?!
It's a cascode of JFETs and BJTs. BJTs are naturally very high gain devices. It makes them highly useful in certain applications such as solid state amps where you want to drive the NFB way up, or use small collector loads to give increased bandwidths, or as CCSs.
No telling what that front end will sound like, though it's used frequently in all solid state designs where it works quite well.
Another one of those cases where you probably won't know until you try.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 28th April 2010, 01:16 AM   #12
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I have a P-P amp using JFETs cascoded with triodes that works very nicely - you can see it by checking the "Kingfisher" thread. This one takes the front end to its logical conclusion - why use the triodes just to cascode the JFETs? I needed the space on the top deck anyway...
Old 4th May 2010, 06:44 AM   #13
wrenchone's Avatar
Amp is proceeding at a slow and steady pace. Just about all the wiring is in place on the top deck and just about all the holes are in the case, except for the pilot light, which will be a deep red first-generation GaAsP LED. The wiring harness from the SMPS to amp top deck is done, and needs to be integrated with the top deck. The bottom plate needs some ventilation holes.
Tasks remaining (not an exhaustive list)
1) Finish top deck wiring, mate with output XFMRS and in/out connectors, and bring up amp with bench supplies to match output tubes, verify bias levels and tweak compensation.
2) Modify SMPS top shield to accept AC in/DC out connectors, perform EMI scan with resistive load with supply mounted in case with shield.
3) After amp is working, disassemble to paint case and top deck.
4) Reassemble, retest, and wreak havoc...
Old 4th May 2010, 06:57 AM   #14
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Lil' Devil P-P Amp
5) Take it to Burning Amp.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 5th May 2010, 12:29 AM   #15
wrenchone's Avatar
That goes without saying - It'll have some company, too, both vacuum and sand state.
Old 5th May 2010, 04:05 AM   #16
diyAudio Editor
Variac's Avatar
Lil' Devil P-P Amp
Old 18th July 2010, 05:12 AM   #17
wrenchone's Avatar
This project has been chugging along quietly in the background, taking back seat at times to some wild-a** ideas. Case and top panel are assembled,and the wiring harnesses are finished. Next step is probably integrating the top deck stuff with output transformers and connectors so I can bring up the amp in a decorous fashion with bench supplies. I'll post pictures when appropriate, but the amp is going to look a bit strange, with four stubby little compactrons sprouting out of the top of a 6" cube.
Old 30th October 2011, 11:24 PM   #18
wrenchone's Avatar
This amp has been sitting around in the basement waiting for me to finish it. In the meantime I've realized that the current design does not address blocking distortion, and have come up with a somewhat different front end that direct couples to the output stage and gets rid of the problem (still sand state, though). I'll post some schematics when I get something working. Though the approach looks straightforward, it's always the actual implementation (and fitting it into a 6" cube) that's the rub. It will also require a different SMPS design, and I'll have to come up with that as well. More later...
This amp will represent another in a series of approaches to realize a push-pull design that addresses blocking distortion and imperfect matching between output tubes. When all the dust settles and I get things finished, I think there will be three or four alternative approaches. All have some sand in them, and I am defiantly unapologetic about it.
Old 31st October 2011, 06:03 AM   #19
wrenchone's Avatar
I'm going to try using the same approach as I'm trying with the Devil to retool the driver board on a modified ST70 that's in progress, eliminating a lot of parts.
Old 31st October 2011, 06:04 PM   #20
Bigun is offline Bigun  Canada
Bigun's Avatar
Lil' Devil P-P Amp
you leave your boards bare copper - no protection ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Lil' Devil P-P AmpHide this!Advertise here!
lil ol me tweetertox Introductions 22 17th December 2008 03:32 PM
a lil help here please... Braveheart Car Audio 1 25th February 2006 05:56 AM
still build...just a lil more help rv1890 Multi-Way 1 22nd January 2006 11:06 AM
Lil chip amp from keyboard parts Tekko Chip Amps 3 28th January 2005 04:43 PM
Lil mids help Radik Multi-Way 1 28th July 2003 02:21 AM
Copyright ©1999-2017 diyAudio
