diyAudio Sponsor
Old 5th April 2010, 03:57 PM   #1
Send a message via MSN to audiodesign
Default Hi-End 50W Push-Amplifier inspired to AudioResearch
see on:
PP2010 - Hi-End Push Pull Amplifier
50W 0.3% Thd with only 5dB of global feedback
Old 5th April 2010, 05:47 PM   #2
Interesting project and nice site!
tubes.rs
facebook.com/tubes.rs
Old 6th April 2010, 08:17 AM   #3
In a direct comparation with my last reference GM70/813 single ended amplifier this push-pull in some case give a better sound.
The bass is more fast and present.
The middle with voice are very clear.
Old 6th April 2010, 05:44 PM   #4
richwalters's Avatar
Nothing new under the sun.
Your'e gonna need global nfb for bass reflex loaded speakers with a Q higher than 1.5 and listening to classics. The article doesn't mention the damping factor value.
The unloaded low end damping will sound much too honky. The split loaded phasesplitter works excellent for a minimal component count. The only slight disadvantage is zero gain.
department of physics
richy
Old 6th April 2010, 06:45 PM   #5
And i´ve heard from ppl that UL doesent sound as good as triode connected of just tieing the screen grids to the plate supply via a resistor.
Old 6th April 2010, 06:53 PM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Did not you see feedback to cathodes from output tranny?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 6th April 2010, 07:54 PM   #7
In a design where introducing a solid state current source to a long tailed differential pair is being looked at, why not consider the high voltage negative supply? It is easily implemented from a preexisting FW rectified positive ground referenced supply with a second bridge rectifier, pair of capacitors and a relatively small CLC or similar filter. Plus you get a fixed bias supply source for free.
I am also curious how much is really gained performance-wise by adding a solid state differential input.
Old 6th April 2010, 07:56 PM   #8
Richy,
here you can see the test informations for the damping
PP2010 - Push Pull test
Old 6th April 2010, 08:18 PM   #9
Thoriated,
use a resistor in the differential with A 100v ac is impossible.
the min value to get 2 simmetric output is 220K/270k
so we need 2mA * 220K = 440V
Old 6th April 2010, 11:02 PM   #10
Hi -
Well, I used a long tailed diff pair cathode resistor to -500Vdc for my DC coupled OTL so that is the sole source of coloration for that portion of the circuit. I also added a small neon bulb to ground to keep the off state cathode voltage from going too far negative, but it has worked flawlessly for over 20 years.
50W amplifier seacucumber Class D 1 10th February 2010 08:38 PM
Need help on understanding AudioResearch like output stage Cede Tubes / Valves 13 3rd January 2010 01:31 PM
The Smallest 50w Mosfet Amplifier covik Solid State 10 5th November 2006 11:47 PM
Kaneda 50W Class A amplifier vt4c Solid State 0 1st July 2003 05:03 AM
50W FM Radio Amplifier Myren Solid State 4 14th April 2003 06:35 PM
Page generated in 0.09604 seconds (76.13% PHP - 23.87% MySQL) with 11 queries
