Old 14th June 2011, 08:55 PM   #11
milosz is offline milosz  United States
Yes it's true that the tube's power capability is fixed, based on the tube design / construction. However, a lower feedback design will have more distortion as you ask the tube for more power- while a higher feedback design will let you push the tube harder. If you arbitrarily set 1% THD as the maximum allowable distortion level, the low NFB design will produce less power at that limit.
Here you can see that you can get about 3 watts at 8 ohms at 1% THD with high negative feedback, and less than 2 watts at 1% THD without NFB.
Cayin A-300B, 4 ohm tap, high negative feedback, distortion (%)vs 1kHz continuous output power into (from bottom to top at 1W): 16, 8, 4, 2 ohms, one channel driven.
Fig.7 Cayin A-300B, 4 ohm tap, zero negative feedback, distortion (%)vs 1kHz continuous output power into (from bottom to top at 1W): 16, 8, 4, 2 ohms, one channel driven.
Old 14th June 2011, 09:59 PM   #12
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Ok, you are correct if using the 1%THD rating for output power. I was reffering to maximum output (clipping).
Old 30th January 2013, 06:10 PM   #13
Default Long term reliability Audioromy FU-29 amplifier
This amp has been in daily use for about 2 years now, filament on one 6N1 failed (opened) so replaced that tube.
Good reliability.
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 70 15th August 2012 08:08 PM
Yet another Push-Pull croccodillo Solid State 3 2nd October 2009 12:24 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push Pull bellx Solid State 3 25th January 2004 10:59 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
