diyAudio Sponsor
Old 5th April 2010, 06:29 AM   #1
mltube is offline mltube  United States
mltube's Avatar
Lightbulb A Direct-Coupled Amplifier with Cathode Follower 6V6
I found this circuit interesting, and thought it may be of interest to some of you. Have any of you built the same or similar?
File Type: jpg Direct-Coupled-6V6-Cathode-Follower-Tube-Amp-Schematic.jpg (77.4 KB, 532 views)
Old 5th April 2010, 10:11 AM   #2
jueic is offline jueic  Taiwan
Here is another one with very similar DC arrangement..
http://www.plitron.com/pdf/polisois1957.pdf
Old 5th April 2010, 11:17 AM   #3
Merlinb is offline Merlinb  United Kingdom
Incidentally, Mltube's circuit is taken from this article:
http://thermionic.info/bates/Bates_D...thFollower.pdf
Old 5th April 2010, 12:28 PM   #4
jane is offline jane  Norway
jane's Avatar
It is hard to see how the 6SJ7 with just 73V at the plate can produce all the voltage swing needed for a cathode follower output stage.
Maybe I'm missing something?
Jan E.
Life is hard - Then you die.
Old 5th April 2010, 03:59 PM   #5
mltube's Avatar
Thank you Merlinb, the link you provided was helpful. I recieved the schematic from a friend of mine that has since moved away. I had always wanted to build it, but preoccupied with other projects. I will be trying the circuit in the next couple days and will post results.
Thanks again
And thanks to all that responded, much appreciation!
Last edited by mltube; 5th April 2010 at 04:05 PM. Reason: Forgot to thank others also
Old 29th March 2011, 02:55 AM   #6
Hi Mltube - how did this amp turn out?
Old 31st March 2011, 06:41 PM   #7
mltube's Avatar
I haven't been able to do much, fighting issues with ultra rare lung disease. No cure, but electronics makes everything seem better.
I have been working on battery powered tube regen radio lately, (safer then HV) meds make hands shake to much with hv.
Thank you for responding, I will see if I can get the cathode drive 6v6 circuit going soon when things get better. It is not my design, but looks like it has good posibilities.
By the way how's the weather in Winipeg? I am originally from Warroad, just across the border. I sure miss Lake of the Woods area.
Sorry very off topic, stuck in house 24/7....
Michael
How to design a direct coupled SE amplifier? keithpeter Tubes / Valves 2 3rd September 2009 08:59 PM
Direct-coupled cathode/source follower driver in PP? ray_moth Tubes / Valves 83 17th July 2008 02:53 AM
Question about biasing heater above cathode in a direct coupled circuit. G Tubes / Valves 1 26th May 2007 11:42 AM
An intriguing 300B SE-direct-coupled-amplifier Antonio Tucci Tubes / Valves 27 8th February 2006 09:34 AM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Page generated in 0.09562 seconds (71.85% PHP - 28.15% MySQL) with 11 queries
