| diyAudio Sponsor | ||
Hiya all, i've made a amplifier useing a pcl84 valve useing this plan
http://www.diyaudio.com/forums/attac...4&d=1152603590and it goes pretty loud and sounds really good ![]() I was wondering if one of these transfomers would work well. what do you think??? --|P037T|100V TRANSFORMER 8W | CPC 600-OHM INPUT AUDIO TRANSFORMER FOR R390 R390A RECEIVER on eBay (end time 03-May-10 14:18:26 BST) Thanks for looking |
#2 |
diyAudio Chief Moderator
First one is for commercial sound speakers tapping off 100V lines. Each roof or wall speaker in large buildings has one inside. Bad quality, mainly for the vocal range. Primary voltage I don't think they can take safely over 100V.
The second one is milspec. Very low primary impedance. I don't see the circuit for your link. |
#3 |
Hi, thanks for the help
http://www.diyaudio.com/forums/attac...udio-ecl84.jpg (if this link works) |
#5 |
Do a search on output transformer. This is what I spotted, and it would be fine for your amp when used with an 8 ohm speaker:
1 OUTPUT TRANSFORMER 5.6 K - 4 OHM 3.5 WATT 6V6 on eBay (end time 05-Apr-10 13:19:05 BST) |
#6 |
Or find someone who restores old valve radios, and talk them into letting you have an output transformer (I'll bet the one in the auction comes from a radio)
#7 |
Hi thanks Salsa and Rotaspec for the tips and help.
I'm new to valve amplifiers |
#8 |
Hi sco1t,
No, it wouldn't. Transformers and things like speakers are measured for an AC impedance, not a DC resistance. Normally the impedance is rated in mid-band. If you were to measure the resistance of a speaker, it would only be about 75% of the rated Impedance of the speaker. For instance, a power transformer may only have a resistance of a few ohms. Yet if you calculate how much current it would draw connected to the AC mains, it's clear that the working impedance must be a lot higher (it is). Instruments that measure inductance, capacitance and impedance (an LCR meter or impedance bridge) use an AC voltage or current to develop a voltage drop across the component. They calculate the impedance from that. Often the test frequency has several values to cover a larger range. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#9 |
Edcor make good audio transformers to resanable prices.
#10 |
Maybe this helps? It describes how to determine the output impedance of your OPT.
Output Transformer Impedance |
| Testing valves/tubes | Joe of Loath | Tubes / Valves | 4 | 18th January 2010 06:53 PM |
| CCS for tubes/valves: PCBs | SY | Tubes / Valves | 340 | 20th October 2009 02:43 AM |
| Techtube valves/tubes | geoff4valves | Tubes / Valves | 10 | 21st October 2008 05:01 PM |
| 10,000+ AUDIO Type tubes for sale or trade | DrRick | Swap Meet | 25 | 20th June 2008 06:39 PM |
| Valves-tubes-mosfets- | Graeme | Tubes / Valves | 0 | 21st February 2002 04:47 AM |
| Page generated in 0.10044 seconds (78.46% PHP - 21.54% MySQL) with 10 queries |
