| diyAudio Sponsor | ||
Hello all, I'm a relative "newbie" from Australia.
I've been building amps for a few years now - mostly 2 x EL84 in push-pull for 15W guitar amps for myself and a couple of mates. I've come up with a great formula over that time, using 1 x ECC83S (12AX7) and 1 x ECC82 (12AU7) in the pre-amp with a TMB tone-stack. I included Master Volume and Gain controls to provide a bit of extra versatility. I've settled on a bridge rectifier based power supply for the sound I was chasing. I'm pretty happy with the 2 x EL84 power supply I've developed (check out the attachment) - but confused when it comes to adapting something similar to a 4 x EL84 amp. Do I just beef up the VA on the power transformer secondary to 87 (280V @ 310mA? That is, add an extra 65mA each (max) for the 2 extra EL84's or would I also need to beef up the the first stage RC network. If so - any ideas? I'm just trying to make the new version as reliable as the old one. If you'd like to see the 15W power amp or my proposed 30W power amp, I can post those as well. Sorry to rave on, but any help would be appreciated. |
#2 |
Hi Eric,
I presume when you say 4 x EL84 you are planning to operate in parallel push-pull (PPP). Roughly speaking, the power supply will need to deliver twice the current, so indeed your transformer should be able to handle twice the load, but the voltage drop across your resistors in the CRC network will also be twice as much. The best way to think about the design is that you want two power supplies in parallel to give the same performance as what you have now driving two tubes. This would mean double the capacitance and half the resistance in the CRC network. In truth, this may be neither practical nor necessary. Try out PSUD to compare the ripple and voltage sag under load for different configurations. Note also that your output transformer will need to have half the input impedance to have similar performance to your current design. -Eric |
#3 |
If the tubes are running class A you probably won't have to upgrade the driver stage. But if you are running AB or B, you will need a stronger driver. Otherwise the grid current will overload it.
When paralleling tubes it's wise to include parasitic suppressors in the grid and plate leads, say 100 Ohms for a wild guess. |
#4 |
Thanks for your help so far Torrence and Bob91343.
Yes, I forgot to mention that the 4 x EL84's would be in parallel push-pull. I've added 2 more attachments showing the current 2 x EL84 power amp and the 4 x EL84 power amp as it will probably be built. I can't go much further with the turret board until I settle on the power supply components. What do you guys think? Last edited by Eric Lawson; 3rd April 2010 at 07:07 AM. |
#5 |
#6 |
#7 | |
For the 30W (4 x EL84) version, after torrence's coments, I was thinking of putting an extra 47uF Electrolytic before point A and changing the A-B resistor to 470R 5W as well as increasing the last 2 Electrolytics (C&D) to 15uF. Do you feel it necessary to increase the second (point B) 47uF Electrolytic as well? I guess the new board will be about 25% longer to accommodate the extra components. Thanks again for the tips guys! |
#8 |
Taking your various suggestions into account, this is what I had in mind for the 30W (4 x EL84) power supply. Is it worth a try?
#9 |
#10 |
Nice soldering work there Eric. Very neat. I need to take this approach.
| Unity-Gain EL84 Push-Pull Power Buffer | Kashmire | Tubes / Valves | 9 | 11th February 2010 02:27 AM |
| 6BQ5 Push-Pull amplifier | YFW | Tubes / Valves | 6 | 7th June 2007 10:18 PM |
| EL84/6BQ5 Ultra-Linear Push-Pull Recomendation | diegot | Tubes / Valves | 17 | 5th April 2007 11:41 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Double EL84 Push-Pull supply | Elkaid | Tubes / Valves | 44 | 30th January 2004 06:26 PM |
| Page generated in 0.09652 seconds (87.42% PHP - 12.58% MySQL) with 11 queries |
