| diyAudio Sponsor | ||
As you might have guessed ,I'm new to tube circuits. I purchased a few pre built tube preamp boards for use as a gain stage in resistor i/v on some TDA1541 cd players I have. The boards are straight forward , with very easy hook-up. 120vac , 6.3vac , input , output. Bridge diodes are included onboard for each power supply. I'm currnetly using Line voltage 120vac and a 6.3vac transformer for heaters. The circuits works fine. In my shop , I use a 2 channel reciever for testing. Everything worked fine, sounded very good , and I was quite proud of myself
#2 |
The problem is simple. You must isolate the 120 V input with a transformer.
#3 |
Indeed. I have a large 100W amp in my basement that works this way. I have never plugged it in for this reason. Get a transformer!
#4 | |
So I need a 120v-120v trans? Thanks |
#5 |
You are tying the circuit to your home's mains. Depending which way you wired the hot and the neutral to the circuit, one of them becomes the common in the amp. If you then plug that into a component that ties its signal common to earth ground, you have just shorted that leg of your home's wiring to earth ground. In your case, it sounds like you have the hot side appearing as the common. You have been lucky that you have not been shocked.
It's possible that either the outlet in your shop or your home has the hot and neutral reversed, which is perhaps why you didn't receive a shock while in the shop. |
#6 | |
#7 | |
DO NOT SCREW AROUND WITH DIRECT CONNECTED SUPPLIES !!! (until you know exactly WHAT you're doing) If you're not having trouble connecting to some units it because THOSE transformers are covering your butt. It you touch your 'ground' and a true earth ground, you will get a nasty potentially lethal shock. If I seem harsh, it's to keep you around. Always always ALWAYS use a transformer for your projects and experiments. G² |
#8 | |
#9 |
I would add at least two or three more ALWAYS's.
In the old days they had electronic stuff that wasn't isolated. They solved it by putting the gear into plastic cabinets, insulating knobs, and kept the chassis covered. If there was need for an external connection, they isolated it with a capacitor but there were lots of hum problems. I had a cute one tube radio as a kid. It almost killed me a number of times. |
#10 |
It appears I was mislead by the seller , but I suppose I should have known better. What usually makes sense, should be obvious. Please see pic below.
Can anyone suggest a good transformer for this circuit? Maybe a link? Thank you all for saving my butt. Paul |
| Keep Blowing Fuses | Whiting | Tubes / Valves | 9 | 11th September 2008 09:44 PM |
| Why are these fuses blowing | Darin P-B | Solid State | 41 | 30th May 2005 10:56 PM |
| Blowing fuses | balance | Tubes / Valves | 2 | 5th March 2005 02:16 AM |
| blowing fuses | homegrown45167 | Car Audio | 2 | 22nd October 2004 12:16 PM |
| The Fuses Just Keep Blowing | raffir | Chip Amps | 19 | 22nd June 2003 03:49 AM |
| Page generated in 0.10646 seconds (81.24% PHP - 18.76% MySQL) with 11 queries |
