OTL preamplifier
OTL preamplifier
Old 13th June 2003, 05:44 PM   #1
filippo22 is offline filippo22
Default OTL preamplifier
Hi guys
I found some input transformer with separate secondary windings, good also for a phase splitter. Starting from my first idea, a friend made the following circuit for an OTL preamplifier.
I'm waiting for building the first prototipe and any previous comment is sincerly appreciate
thanks a lot
Filippo
www.audiofanatic.it
Old 13th June 2003, 06:36 PM   #2
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
Filippo
This is one weird circuit. Or i do not understand it Why do you call it OTL? After the splitting transformer both phases seem to pass through their respective 100uF caps, right? This can't be too good...
peter
Old 13th June 2003, 07:00 PM   #3
I called OTL only because the stage is like a tipical OTL amplifier, the HT is made with a dual PS, and the signal is taken at a virtual zero volt point between the two tubes. Anyway I put a condenser, because a little offset may occour, due to the tolerance of tubes.
The 100mF condenser is only a cap for avoid some residual hum because the fixed neg bias is taken directly from the heater supply and regulated with the pots.
Yes, is a weird scheme, I attach the first simplest idea when the basic circuit is better showed
... and sorry for my very maccheronic english
ciao
Filippo
www.audiofanatic.it
Old 14th June 2003, 01:29 AM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Confused.
It's a balanced input White cathode follower. Why? You've gone to a lot of trouble to design an expenisive active stage having a gain of one.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 14th June 2003, 02:40 AM   #5
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Actually it is not a white CF. It has absolutely no NFB, aside from that in the triodes themselves. They are fed in such a way as to negate the characteristics of a CF. For this reason, the circuit seen in the 3rd post in this thread is incorrect; the top tube is a cathode follower, while the lower is not.
It's just an elementary form of a SEPP circuit, thought the arragement of the schematic is a little confusing.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 14th June 2003, 11:46 AM   #6
EC8010's Avatar
Sorry, but it is. If you look at the patent, you will find that there are two distinct circuits given. One has a feedback loop down to the lower valve, and the other is this one.
Old 14th June 2003, 07:43 PM   #7
Sch3mat1c's Avatar
The other is which? The post #3 circuit?
Tim
Old 14th June 2003, 08:08 PM   #8
EC8010's Avatar
Yes, UK patent 564, 250 includes the circuit in post #3 (although not with a transformer phase-splitter).
OTL preamplifierHide this!Advertise here!
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Mic PreAmplifier Ayne Solid State 4 13th April 2007 03:18 AM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
Preamplifier DIY Angel Puerto Solid State 13 20th July 2005 08:53 PM
help with preamplifier skobo Solid State 9 15th July 2005 12:54 PM
