| diyAudio Sponsor | ||
Hope this is the correct area to start this thread...anyway in the January 2010 Elektor magazine it has an article on a PC USB load indicator using a EM84 Magic Eye tube.
http://www.elektor.com/magazines/201....1191254.lynkx I was after some advise to use this as a base for an audio line level VU meter. The main advantage is it works off the USB 5V supply so was after keeping this and running it off a 230/5V plug in mains unit. Cheers John Last edited by seroxatmad; 26th March 2010 at 12:55 PM. Reason: Added link |
#4 |
No mention of where the tube is powered from, but it's gotta be one heck of a step up power supply to get 250v from 5v. Never mind the 6.3v heater. I don't know what the min plate voltage is for these, but I've always seen them running more than 200v. I had one of those tubes but the phosphor was completely gone. There is a Russian version available.
#5 |
It is 250V, but at relatively low current. USB can source up to 500 mA to a registered device so consumption should within standard specifications.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#6 |
Here's a circuit dug out from my old Radiogram. Note; the EM87 display circuit registers peak values as per RF modulation /tuning, and to show rms, the circuit needs modification for audio VU meter apps.
richy |
#7 |
Hi
Thanks fro the replies... The 6.3v heater and the 250v is supplied from a self wound pcb mounted transformer via the USB supply but would like to ditch the USB part and run off a 5 or 12V mains plug in unit, and line level source. Note pin 1 and 9 is not used in this configuration. Cheers John P.S I am after getting a circuit working to make onto PCB to make as a group buy in the future. Last edited by seroxatmad; 28th March 2010 at 06:47 PM. Reason: added pic |
| Elektor USB magic eye | seroxatmad | Tubes / Valves | 3 | 26th March 2010 04:56 PM |
| Anyone make a VU with a magic eye ? | Colt45 | Tubes / Valves | 6 | 19th October 2005 08:39 PM |
| Playing with a Magic Eye. | Shoog | Tubes / Valves | 7 | 13th January 2005 09:33 PM |
| Page generated in 0.08146 seconds (76.49% PHP - 23.51% MySQL) with 11 queries |
