| diyAudio Sponsor | ||
Hallo, I have purchased this amplifier and I want to upgrade the internal circuit but there are many type on web.
Someone is kind enough to post one seriously working circuit with all correct value ? Regards Paolo |
#2 |
Also, my version have 6n1p tubes.
The common of the output trasformer is grounded or not ? |
#3 |
There are a number of smaller differences between different deliveries of these amps, so the best method to get a circuit diagram that is correct for your amp is to mark up your own version of the diagram.
If you feel competent to improve the internal circuit, you should also be able to correct the published schematic - with a little effort.. The 6n1 tubes can successfully be replaced by ECC85. The common of the OPT is grounded since the amp applies some (moderate) GFB. If you operate in triode mode you can disconnect the GFB if you want, and make the output floating. Here is a link to a diagram I helped a friend to mark up for an amp he had got early this year: Music Angel: DIY Skjema for MA KT88 Your amp may be different. Svein. |
#4 |
Many thanks,seem the same.
Danish, very hard to translate !!!!!!!!!!!!!!! |
#5 |
In that forum there is one dedicated section for a Music Angel KT88 type !!!
#6 |
Can be considered ok this wiring modification for a god listen ?
Paolo |
#7 |
| Help! Upgrade a Music Angel KT88 | leimaster | Tubes / Valves | 47 | 11th March 2012 11:10 PM |
| music angel kt88 | vitalstates | Tubes / Valves | 1 | 27th February 2008 04:31 PM |
| Please tell me how to upgrade Music Angel KT88 amplifier? | hififactory | Tubes / Valves | 26 | 29th December 2007 03:04 PM |
| Page generated in 0.08414 seconds (76.11% PHP - 23.89% MySQL) with 11 queries |
