| diyAudio Sponsor | ||
I have a tube marked
3223 5712. I have looked and looked but cant find any information about it. Can anybody help? |
#2 |
That may be a date code 322: Tung_Sol, 5712: 1957, week 12. Got a picture?
#3 |
It seems the anode of one section comes out on pin 9
Heaters are 4/5 and pin 8 |
#4 |
Sounds like 5687 - Tung-Sol made plenty of those... heater draw of .45A at 12V would another bit of evidence that it's a 5687.
#5 |
Yes, I think you are correct, I have found a 5687 and they look identical.
Thanks for your help. |
#6 |
Hi, I have a similar tube labelled 3223 5708. Could it also be a 5687?
#7 |
I have a bunch of these too. The 3223 is the common number the 5718 is different on each tube so I believe it is a date code. They were mixed in with a bunch of 5687's and seem to work in the same circuits. All are military pull outs and all were simply dumped together in a large box (about 40 pounds). Most of the thousands of tubes that I got in that lot were from the 1950's.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#8 |
Looks the same as mine.
5687 |
#9 |
Thanks for the help, guys. Appreciate it.
#10 |
Datasheet here if you need it: http://www.mif.pg.gda.pl/homepages/f...8/5/5687WA.pdf
It's a low mu twin triode, mu = 17, transconductance = 11k A little bit like a 12AU7 though more transconductance. If it wasn't for the funny pinout, you could try them where 12AU7s are used. You could build a pinout converter adapter if you can find a male 9 pin plug. If you have tons of them, you could build circuits that need lots of low mu twin triodes.
| iwatsu scope manual ss 5712 | SUE | Parts | 1 | 9th September 2009 04:44 AM |
| 405-2/1 service data needed | Craig405 | Solid State | 10 | 30th July 2006 09:14 PM |
| Tube Data needed please | georgehifi | Tubes / Valves | 5 | 25th June 2005 09:15 AM |
| outputtransformer data needed | goudfazant | Tubes / Valves | 0 | 17th December 2004 07:50 PM |
| Page generated in 0.09485 seconds (76.07% PHP - 23.93% MySQL) with 11 queries |
