Capacitor explosion. - Page 5 - diyAudio
Old 14th January 2013, 10:27 AM   #41
DF96 is online now DF96  England
Cathode resistor too small, failed open circuit so full current/voltage fed into bypass cap?
Switching off quickly then attaching a meter might have given you an opportunity to learn fault-tracing techniques.
Old 14th January 2013, 01:27 PM   #42
Cassiel is offline Cassiel  Libya
Cassiel's Avatar
Yep, that's the standard procedure. This time it was late and I was pretty tired and.... I just let it go. Laziness. This is the second time I do this. As for the reason of failure I can only think of two possible scenarios: the tube's central pin was missing so I may have plugged it the wrong way or it was a loose wire that I forgot to remove and may have caused a short (the cap was correctly wired).
Don't go hard on mistakes - they often teach you valuable things.
Explosion in Forte 1A... needtubes Pass Labs 26 2nd July 2010 10:39 PM
Preamplifier damaged explosion Class-d Crest lee1976 Class D 2 21st November 2009 06:39 PM
what is this capacitor? ASSaBeong Parts 2 7th April 2007 03:13 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Capacitor or not? future Parts 2 24th June 2003 11:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
