#11 |
Yeah, the Mythbusters had some fun testing the hot water heater myth!
I think everyone should take a little more precaution in powering up vintage electronics with big caps, since we never know which ones will blow and which won't. A variac is a good tool to help, but without monitoring the current through the filter caps, you won't really know when they'll try to blow. Kyle |
#13 | |
In a former lifetime I used to build computers for resale (the 286 era). Some friends and I pooled our money and bought out a vendor that sold components in the Computer Shopper magazine. There was a virtual mountain of returned goods in the back of the warehouse. I got at least a hundred "AT" power supplies. On the first pass I just tested them all using a car headlight for a load and sorted out the good ones. Later I opened each one and put a clip lead across the fuse (yeah even then I new better) and retested finding more good ones. Unfortunately I found one with shorted diodes and the result looked a lot like this, including the stuff stuck to the ceiling. It was one of those "ohnosecond" moments when you realize the instant the plug hits the outlet and the lights dim that you screwed up. Before the brain decides to yank the plug, and the body reacts and finds out that its welded into the outlet (the ohnosecond) the cap went BOOM!
After that I modified my technique to incorporate a 100 watt bulb in series with my clip lead "fuse". Quote:
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#14 | |
I had potential difference in a very long serial cable with no opto isolation blow up an UART once, it made a hole directly in the middle of the UART chip where the silicon die used to be. The cover was on fortunately. ICs (at least not the power stuff) are waaaaaay less prone to explosions than electrolytics but I learned my lesson.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#15 |
All the best stuff comes from Chian
If the die that punches the grooves for the vents isn't perfect, they will go boom. I have yet to blow up a cap in a tube amp. I have blown up a few in computers, especially cheap power supplies and VRMs. They use the cheapest caps they can find and they never seem to vent as they should after being cooked for years. A few times the PSU case was packed with aluminum foil and paper confetti after the bang.
Flamed plenty of tants, though. P U. |
#16 |
Working with solid state and high voltage always use safety specs and ear defenders. When an Isotop or bigger leaves it's footprint, it's a trip to the surgury to take out the scrapnel.
richy |
#17 |
#18 | |
#19 | |
I fried a whole bunch of tants one day as a teenager. I was inexperienced and didn't notice that the polarity marking on the body was for the POSITIVE terminal and not the negative like electrolytics (whose bad idea was that?). My dad got a chuckle out of that. Man those things stink, especially when a half dozen go at once.
#20 | |
The capacitor was brand new, installed correctly and operating well within its ratings. I smelled something burning, and it was too late. The capacitor decapitated a transistor in a TO-5 can which was in the driver stage of a mosfet power amplifier, needless to say its failure took out the output mosfets as well. What a mess...
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
| Explosion in Forte 1A... | needtubes | Pass Labs | 26 | 2nd July 2010 10:39 PM |
| Preamplifier damaged explosion Class-d Crest | lee1976 | Class D | 2 | 21st November 2009 06:39 PM |
| what is this capacitor? | ASSaBeong | Parts | 2 | 7th April 2007 03:13 PM |
| 200w Amp + 900w Sub = explosion? 56k Warning | Daemonicus | Subwoofers | 2 | 31st May 2006 04:30 AM |
| Capacitor or not? | future | Parts | 2 | 24th June 2003 11:10 PM |
