diyAudio Sponsor
Old 20th March 2010, 10:43 AM   #1
Default My take on a modern ST-70
Something a little different this time. Take a classic design Dynaco ST-70 and bring it up todate with some circuit changes and better parts. Then, throw in a totally new chassis and cabinet.
The layout begins on some aluminum sheet.
Old 20th March 2010, 10:45 AM   #2
I drilled, cut and punched the chassis. Bend the back down for all the inputs and outputs. Then take it over to the local chrome shop for a bright finish.
Old 20th March 2010, 10:47 AM   #3
I used Baltic birch to create a new cabinet design. The metal chassis slides in from the back.
Old 20th March 2010, 10:49 AM   #4
Here is a picture from the back. The rectangle cutout is for the Corcom power module. The inputs are on the outside edges and the outputs are in the middle.
Old 20th March 2010, 10:52 AM   #5
Now a lot of wiring to do. I spend a lot of time working on layout, wire runs and esthetics. It must only sound good, it has to look good too.
Old 20th March 2010, 11:17 AM   #6
Loren42 is offline Loren42  United States
Awesome looking job so far! Cabinet idea is a great idea, too
The PCB board in the last picture is your design? What will be electrically different with your version versus the original?
Old 20th March 2010, 11:21 AM   #7
SY's Avatar
I am delighted to see someone pay the proper attention to output tube ventilation. Nice work! Electrical details would indeed be interesting.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th March 2010, 11:29 AM   #8
kavermei's Avatar
Send a message via MSN to kavermei
I like those wooden sides, nice idea. Keep up the good work!
Never send a human to do a machine's job. --Agent Smith
Old 20th March 2010, 11:36 AM   #9
The driver board is the brainchild of Shannon Park. This accounts for most of the real design changes. Most others have to do with different parts dealing with filtering or the ability to roll different tubes.
Here is a detailed page on this build: Wardsweb Dynaco ST-70 Project
Old 26th March 2010, 02:36 AM   #10
This is what all this turned into:
ST-70 strangeness Pyre Tubes / Valves 19 2nd September 2007 12:33 AM
Which ST-70 ? percy Tubes / Valves 21 4th September 2004 06:11 PM
St-70 Jack Thomas Swap Meet 1 21st May 2003 03:15 AM
Dynaco st-70 toenail Tubes / Valves 9 19th April 2003 11:08 AM
St-70 Jack Thomas Tubes / Valves 1 13th January 2003 07:24 PM
Page generated in 0.09824 seconds (78.47% PHP - 21.53% MySQL) with 10 queries
