| diyAudio Sponsor | ||
6DJ8 (balanced) tube line stage
Hello These line stage can be used as a balanced line stage to drive amplifier like Aleph X etc .. Any idea ,advise welcome . ![]() Thanks Greets gabor |
#2 |
In theory you can use the illustrated left / right channels as hot / cold phase of a balanced line stage. However in practice the two channels / phases in this design do not cross-reference to each other, and therefore are not always going to be 100% balanced.
Probably best to leave this as an unbalanced line stage, and look for other solutions. Consider transformers as a good way to achieve balance, and also have a read of some of the articles here: John Broskie's Guide to Tube Circuit Analysis & Design (such as Balanced Aikido and http://www.tubecad.com/june99/page7.html) Also consider buying TubeCAD software (not so expensive) to help you with design of a balanced stage. Regards, G. |
| 6DJ8 (balanced) tube line stage | gaborbela | Tubes / Valves | 1 | 18th March 2010 07:20 AM |
| 24v tube buffer & line stage schematic | Bem-bem | Tubes / Valves | 18 | 16th December 2009 01:13 PM |
| 6DJ8 Tube Phono and Line Preamp | Inrush | Tubes / Valves | 4 | 12th November 2009 09:04 AM |
| balanced line stage schematic needed | jogas | Tubes / Valves | 3 | 11th September 2005 08:57 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Page generated in 0.06887 seconds (68.40% PHP - 31.60% MySQL) with 11 queries |
