What tube is this?
What tube is this?
Old 17th March 2010, 08:06 PM   #1
hidnplayr is offline hidnplayr  Belgium
hidnplayr's Avatar
Default What tube is this?
I can't seem to figure out wich tube this is.
It looks to me like a light bulb with a 8-pin side contact socket.
It only has 2 connections.
The top captions reads as [R19] philips miniwatt, then tube type isnt very good readable, looks like C9 below that is a code: N3
I think it's some stabilisator tube, but would like to find the specs
On the side of the tube are the letters ONYX in black
Real tubes have top-caps
Old 17th March 2010, 08:18 PM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Mebbe a projection lamp,or a ballast tube. Just a guess.
Old 18th March 2010, 12:57 AM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Well, it's not R19...
http://www.mif.pg.gda.pl/homepages/f.../155/r/R19.pdf
What resistance is it?
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 18th March 2010, 08:41 AM   #4
hidnplayr's Avatar
I found some info about it on the radiomuseum: C 9, Tube C9; Röhre C 9 (C9)
It's a 200mA current regulator.
What tube is this?Hide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
Simple Tube Mono Block Tube Amp Schematic jleaman Tubes / Valves 16 24th November 2009 08:42 PM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
