| diyAudio Sponsor | ||
Can anyone suggest a tube amp, ideally along cheap simple lines ? A kit would be nice but already built is okay too.
The one must have is tube slop -dripping with the stuff, tons if possible, fidelity not important. I've got a nice little starter kit tube amp built, have a low-mid range one on the way, that I'm saving for. So all set for clean sound. However this is for something else, more for experimentation, kind of A-B compare with other amps. Know this sounds contrary. It's for a learning thing, and to check out some ideas. Any suggestions much appreciated and thanks. PS So far all I'd found is PAiA 's HiFi Tube Preamp (http://www.paia.com/tubestuff.asp if curious) Last edited by infobot; 16th March 2010 at 10:16 PM. Reason: search results so far |
#2 |
define "slop". SE harmonic signature? Slow rise into soft clipping? PP crossover distortion? 32db of gFB via an underspecced OPT?
If you want just a poor design that lacks fidelity , there are plenty out there. Alternatively, start with a GOOD basic design and build in the error you are seeking
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
Hmm thanks good point sorry thought it was much more characteristic, identifiable.
I guess sort of a bloatish liquidy kind of thing, maybe sometimes grainy but more a liquid bloat kind, very syrupy extra overlay to the sound. I guessed hard to miss but hearing what you said, now I second guess myself. Last edited by infobot; 16th March 2010 at 11:24 PM. Reason: mispell |
#4 |
... so the aural equivalent of a supersized Macca's thickshake?
#5 |
Yup like underwater listening.
Used to be common, hear about it some anyhow. Probably before tubes reappeared and we all relearned many more ins and outs of them. Of course then again I could be very way totally wrong there, but pretty sure I'd heard it about and heard the phenomena so to speak. |
#6 |
I have seen a ready built hybrid tube amp module on ebay.
The heaters are dropped off the dc rail so a complicated and expensive transformer isnt needed.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#7 |
A 12AU7 in the preamp section might get you that sound...chocolaty tube.
For some reasons that I don't understand a NOS 12AU7 sounds GREAT in a mu follower configuration. I have the suspicion that the reason why that tube is often used in PP pentode amps is to soften the edgy sound of pentodes but I might be wrong. In theory feedback solves that problem.
Good sound comes and goes. |
#8 |
OK, I've found this for you. Owner says it sounds like a drunken Frenchman, slow and slurry. Sweet, dark euphonic sound.
#9 |
Much thanks.
The idea of a hybrid's, any idea what they sound like? Was thinking all tube but that's just because anything else hadn't occured to me. That schematic sounds like just the thing. Is that a Jadis ? (picture's tagged Jadis) Just surprised but hadn't read up on their stuff in ages, used to hear about them in audio mags. ****** I'd 'inherited' a couple of old console stereos a long while back, someone cleaning out their cellar. Nothing valuable, budget line models. Anyway not very hifi but between the amp and speakers got some weird results. Huge open sound but wasn't just the tubes. One had two small cabs, the amp was in one. The other had 3 channels, 2 stereo and a mono 18" speaker. All had open back cabs. I'd long since gotten rid of them-grabbed them for the wood didn't expect them to fire up. Anyway just intrigued me that lofi setup (they sounded it) could sound that good, well so deep and wide. Both sounded much like the Jadis description, probably same or more exaggerated. |
#10 | ||
| Simple Tube Mono Block Tube Amp Schematic | jleaman | Tubes / Valves | 16 | 24th November 2009 08:42 PM |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| Needing opinions, the "return of someone that had never departure" | destroyer X | Solid State | 40 | 30th October 2005 12:40 AM |
| Page generated in 0.11978 seconds (80.87% PHP - 19.13% MySQL) with 11 queries |
