Wire construction for capped tube plates
Old 16th March 2010, 06:54 PM   #11
TheGimp is offline TheGimp  United States
TheGimp's Avatar
5KV rated 18AWG (65x36) rubber insulated 90 degreeC, breakdown voltage 20,000V.
Sounds like a good choice to me.
Old 16th March 2010, 08:32 PM   #12
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
another vote for meter lead wire. Works great on my EL36/6DQ6/807 amps...
You can go punk and use a crocodile clip for the termination, but a cage is then a must have!
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 16th March 2010, 09:10 PM   #13
tomchr is offline tomchr  Canada
tomchr's Avatar
What's a good source for the flexible test lead wire in low quantity (preferably by the foot/meter)?
~Tom
Old 16th March 2010, 09:28 PM   #14
HollowState is offline HollowState  United States
HollowState's Avatar
I too like test lead wire from Belden, #8899. It's 5KV 18 gauge rubber covered. I get it on eBay when it shows up. I also like Markel #3239 silicone covered. Very heat resistant (150C) and very flexible. Good to 30KV but not too thick. There is someone on eBay in China selling HV wire that appears very similar and in various sizes. I've never used it though so I can't be totally sure what it's like. Search for *high voltage* (under business and industrial) and you'll find it in short lenghts.
Old 16th March 2010, 10:19 PM   #15
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I use the silicone ultraflexible wire favored by model car enthusiasts. It has high temperature capability, withstands the voltage, and is available in a variety of colors (red, blue, black, and yellow). No need to use any gauge larger than 18...
Old 17th March 2010, 12:07 AM   #16
refference is offline refference  Brazil
Originally Posted by moonbird View Post
Hello all --
What type of insulation is best? cotton? teflon? How about gauge? Stranded or solid?? Thx much!
Hi moonbird ,
When connecting tube caps , I ALWAYS use SILICONE insulated , stranded wire, rated for 300 C , 1.0 or 1.5 mm2 , and a ceramic cap ( forget about
any plastic insulation for the wire or the cap ,like PVC , mylar , etc , all of them will melt ) . You can buy it by meters ( or feet ) , in any good store that sells electric cables .
Minimum rated voltage insulation : 750 Volts
Teflon is also very good , but the price is high .
Carlos
Old 17th March 2010, 11:01 AM   #17
Shoog is offline Shoog
Shoog's Avatar
I sources my meter wire from dead meters. After you've been in the hobby for a while there's usually plenty of them about
Shoog
Wire construction for capped tube platesHide this!Advertise here!
Running Tube Amp Construction PassFan Tubes / Valves 138 12th January 2012 05:39 AM
Tube construction materials SpreadSpectrum Tubes / Valves 20 19th August 2008 06:23 PM
Tube Construction Handbook poynton Tubes / Valves 13 22nd February 2008 02:26 PM
Can you SEE (construction) how a tube SOUNDS? Klimon Tubes / Valves 5 31st May 2005 01:29 PM
Preparing to start construction on LeachAmp, all I need is wire? wigginjs Solid State 1 23rd June 2004 08:42 AM
