How many watts are really needed?
Old 15th March 2010, 01:09 AM   #31
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
OK,...OK..........15.94 MB of instructions??????
Nearly Sixteen Mega-bytes of instructions? Even the word Mega....shouldn't be in a tube lovers vocabulary...except for frequencies we are trying to filter out.
That was enough time for me to scrub down the living-room floor.
Thirty two pages of instructions.
And, and SMDs' ????? "Daddy?... were you born when S M Ds' came out"??
So how much of a time gap is that....when the ST-70 came out & SMDs arrived?
What was that saying about a silk purse & a Sows ear?
Really.... I'm NOT trying to still up the pot....with so MANY choices lets think up some more examples. What does George have that would be suitable?
__________________________________________________ ______Rick.....
Old 15th March 2010, 01:18 AM   #32
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I give up, where was that hybrid ?
Much easier to construct !
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 15th March 2010, 01:20 AM   #33
SGregory is offline SGregory  United States
At least the SMD's were big enough for these old eyes to see them.
Technically if the word Mega shouldn't be in a tube lover vocab then am I safe to assume you are interfacing with this site on punch cards?
Living Life Doing the Waltz in 4/4 meter.
Old 15th March 2010, 01:23 AM   #34
Not quite that old !
I used to program for a company on a Sinclair Spectrum and microdrives !
Clive Sinclair once said 48K would be the most anyone would ever need !
Old 15th March 2010, 01:31 AM   #35
I have the power supply from an old 5 Meg Winchester Drive that weighs nearly 100lbs. I use it as power supply for my foam cutter. iirc the platters were 24" in diameter.
Yes we had to use punch cards to enter the programs. We were allowed to use the terminals only after we mastered cards. It was a transistor computer though.
I am not saying the st70 is the amp to build, but I guess if one was REALLY against SMD's then just replace them with a axial type.
Old 15th March 2010, 02:03 AM   #36
Eli Duttman is offline Eli Duttman  United States
AFAIK, George does not yet have a "Simple PP" to sell.
I agree with the comments disparaging SMD parts for DIY purposes. The Triode Electronics ST70 driver board is all through the hole mounting. After some practice, to get the soldering skills up to snuff, the OP should be able to stuff the board and take care of the point to point work needed to complete the project. A 25 W. or so "Rat Shack" iron, along with 63/37 SnPb eutectic alloy/RA flux solder, rates to be satisfactory.
The understandable decision to retain the Polk speakers drives everything else. Speakers 1st, then an amp is proper procedure.
The OP asked about kits. If a scratch build was being entertained, I'd suggest "El Cheapo" style circuitry using 7591 O/P tubes. Power O/P is adequate, the circuitry is comparatively simple, and a separate control center is not needed. Look at the 7591 data sheet. IMO, the "fixed" bias/ultralinear operating conditions set is noteworthy. High bang for the buck Edcor CXPP60-4-6.6K O/P trafos would be used. It's too bad Edcor doesn't offer a model CXPP60-6-6.6K, as that would be "perfect".
Eli D.
Old 15th March 2010, 02:17 AM   #37
For 40$ engineering charge, EDCOR will make anything. Even then it is still a good price/value.
Old 15th March 2010, 02:31 AM   #38
Glowbug is offline Glowbug  United States
Glowbug's Avatar
For a newbie, I'd say that you can't have too much in the way of instructions
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 15th March 2010, 03:00 AM   #39
Jaime is offline Jaime  Uruguay
Jaime's Avatar
This is a nice high quality PP EL84 12wpc.
2 x 12 watt ultralinear EL84/6P14P power amplifier.
I write in English worse than Tarzan
How many watts are really needed?Hide this!Advertise here!
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
watts vs watts Hayden Parts 7 30th July 2006 01:57 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
How Many capacitors for How many Watts? Paradise_Ice Car Audio 48 21st July 2004 06:35 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
