#21 | |
I have seen hybrids upto 900watts peak.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#22 |
Speakers of that kind of efficiency will also reveal noises farther up the signal chain that you'd never hear with lower-efficiency ones...I know I've gone through some preamps on 96dB/W speakers that other people haven't heard anything wrong with on more traditional designs.
Jim J. |
#23 |
The real advantage of going for less than 10watts is that you can keep everything in class A without things getting to big and to hot.
Shoog |
#24 | |
You can build a tube amp with a multimeter and a soldering iron. A scope, a function generator, and a variac are nice to have, but not required to get started. An additional multimeter may also be handy when bringing the amp up but not required. You will use the voltmeter to check your B+ voltage and adjust the bias of the output tubes when getting the amp up and running, among other things. The various ST-70 kits around use different driver topology and tubes, I'm no expert here, but a search will most likely turn up some good info. Again, once built, plenty of tinkering opportunity for trying different driver boards, etc. There is also a dedicated ST-70 forum over at diytube.com :: Index IIRC, there is a kit available for sale over there also. Use good solder, it makes things easier. There are a few people on ebay selling 20' of Cardas quad-eutectic solder for around $5 shipped, plenty to do a couple of amps. The stuff melts and flows like butter, and you'll be chasing less cold joints later. It's nice to bring the voltage up slowly when first firing a newly-built project up. Without a variac, you can accomplish this with a lightbulb in series with the power cord. Search the forum for details. Remember, tubes operate at high voltage, and can be dangerous/lethal. The B+ voltage in an ST-70 kit or similar PP amp is around 400V give or take a little, and this voltage needs to be treated with respect, like using clip leads (highly recommended) on your meter for hands-off testing. If you must probe a live amp always stick one hand in your pocket (use a clip lead on the neg side of the meter). Put bleeder resistors across the HV power supply caps to allow the high voltage to bleed off when the amp is powered down. I imagine modern kits include these..... Read the sticky on safety at the top of this forum for other tube safety basics. If you've got a little soldering/electronics experience, an ST-70 kit is a fine first project. It also can be modified over time so it can keep your interest for awhile. |
#25 | |
Jim J. |
#26 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
""No such thing"" ???
Let me get this right.... your wanting a relative noobie to do an ST-70 kit?? He'll get lost just in the part count! K.I.S.S. Try this one from 'Andreas'" schematics listings..... Class A, really simple....just to get his feet wet. The idea of running a full PP is just asking for him to get discouraged. Besides.... kits really take away the real "fun", point to point wiring, the layout, dimensions......all the real good stuff. __________________________________________________ ___Rick.... |
#27 | |
The OP asked for a kit. He also wants to keep his speakers. The speakers rule low power SE circuits out. More than 1 ST70 has been successfully assembled by somebody "following the dots".
Eli D. |
#28 |
Nothing wrong with a kit for a first time build.
Even a ready made kit is useful. At least with a kit/ready built module you get a pro pcb that looks really good. Some of my point to point builds have been pretty rough even if they have worked !
#29 |
The tubelab kits, although not for this application, were a great learning experience for me. Gave me the opportunity to learn how to calculate values, and then see the answer. Most importantly the success at then end.
While I agree P2P is really fun and an adventure, a kit is a good place to start. Too bad George's PP board isn't ready for press yet.
Living Life Doing the Waltz in 4/4 meter. |
#30 | |
ST-70 Assembly Instructions There are an abundance of pictures in the assembly manual. Not much can go wrong. Add to the fact that the ST-70 has a huge number of followers and the amount of support available for that amp is second to none. |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| watts vs watts | Hayden | Parts | 7 | 30th July 2006 12:57 AM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| How Many capacitors for How many Watts? | Paradise_Ice | Car Audio | 48 | 21st July 2004 05:35 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
