diyAudio Sponsor
Old 7th October 2003, 10:59 PM   #11
diyAudio Senior Member
fdegrove's Avatar
If this amp is to serve in a dual channel system in a reasonably sized room I'd heartily recommend a PP 2A3 amp.
With attention paid to PS design and driver stage you'd be amazed about the amount of power you can squeeze out of them.
There's something about those DHT triodes that just defies logic...
In the smallish studio I usually work from I have a simple two way speakersystem with a 2A3 PP and a Plextor CD-Rom, software controlled.
This stuff rocks, is detailed and throws a stereo image to make quite a few big boys envious.
Moreover, for a CD based system, this is actually one I can listen to for hours.
Spot the Ultranalog analogy and I'll consider you a smart person...
Frank
Old 7th October 2003, 11:43 PM   #12
SY's Avatar
<hijack>
Transducer, I'd suspect the power supply electrolytics. Poke around the input and output rails with a meter and a scope to see if the B+ voltage is the required 390V and that the input is more or less 450V, with low ripple. FWIW, that's the only part I've lost on mine in about 10 years of service and some pretty terrifying modifications.
Make sure you observe appropriate safety precations when poking around high voltages like this. It's WAY too easy to brush up against something you shouldn't, and we don't have so many members at diyAudio that we can afford to lose any.
</hijack>
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
What would you recommend? bjackson Chip Amps 0 21st November 2005 04:17 PM
what do you recommend pd0019 Multi-Way 0 23rd February 2005 06:40 AM
Can you recommend me. jleaman Solid State 1 26th February 2003 10:50 PM
What do you recommend for first DIY? Me@Home Multi-Way 10 23rd June 2002 12:04 AM
How many µF do you recommend for this amp? hugobross Solid State 3 29th September 2001 12:39 PM
Page generated in 0.07705 seconds (64.55% PHP - 35.45% MySQL) with 11 queries
