diyAudio Sponsor
Old 10th March 2010, 09:46 PM   #1
newtube is offline newtube  United Kingdom
Default blue glow, how?
What makes a tube glow blue guys?
is there a particular kind of tube that glows more than others?
Reason i ask is my tubelab sse has chinese 6l6gc tubes that glow with a little blue just after startup but fades after a few seconds but some images i see on here are just divine!
Its purely an asthetic thing but it would be nice to see the blue all the time
Old 10th March 2010, 10:02 PM   #2
Tubie Noobie
My EH kt88 have a nice blue glow on the glass.
Where is the blue glow coming from. Some is asthetic andother times can be spectacular (when it fries)
Living Life Doing the Waltz in 4/4 meter.
Old 10th March 2010, 10:03 PM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
Unless you're talking about mercury vapor rectifiers -
or voltage regulator tubes -
the blue glow you refer to is caused by electrons that are accelerated past the tube structure and hits the glass envelope, where it excites impurities in the glass.
I'm running with a small sweep tube power amp using a 6LU8 tube. One is a Westinghouse brand and does not exhibit the blue glow. The other is an RCA branded tube and this one does glow blue around the pentode section. Increasing the anode voltage increases the amount of blue light emission as the electrons flowing in the tube are accelerated to higher velocities due to the higher anode voltage. This causes more of them to leave the tube structure and hit the glass... The higher anode voltage is not a desirable operating point from a distortion stand point, though.
I'm guessing the reason your tubes glow blue on start-up and then fade is because it takes a while for the bias voltage to stabilize.
If you really, really want blue light, you could pull the tacky, el-cheapo Chinese eBay amp trick and add a blue LED below the tube socket... Or you could buy a bunch of 6L6'es of different brands and see if you can find any that glow blue in your amp.
~Tom
Old 10th March 2010, 10:04 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I know that some Russian 6P3S tubes have a glass that glows blue when bombarded by electrons.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 10th March 2010, 10:36 PM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
6P1P is notorious for blue glow along the screen rods inside the tube.
Then there is the occasional blue glow that is not good:
Old 11th March 2010, 01:16 AM   #6
The 5B/254M produces a nice glow around the glass. See here:
CV428 or 5B254M useful?
Just for fun I hooked one up on the bench this morning and even at 200v/35mA plate it produced a faint blue ring around the glass extending about 3/4" up from the base of the plate structure.
Gary
Old 11th March 2010, 01:39 AM   #7
tubelab.com's Avatar
Mine did when I got them, but now 2 years later they still rock, but don't glow much.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 11th March 2010, 02:20 AM   #8
SpreadSpectrum's Avatar
EH 7591s
Old 11th March 2010, 05:50 PM   #9
Thats the stuff i mean spreadspectrum! its beautiful, i want mine to do that
Old 11th March 2010, 05:57 PM   #10
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
SED KT88s have a very pleasant blue glow on the glass. Not as apparent in the pic, but strong in person:
Their EL34s also glow, especially near the screens.
blue glow on one channel wicked1 Tubes / Valves 10 29th April 2008 01:20 AM
Blue glow confused :( bobhayes Tubes / Valves 50 20th January 2007 05:00 PM
New WE 300b's blue glow TubeHound Tubes / Valves 26 31st March 2003 01:22 PM
Blue Tubes the glow jleaman Tubes / Valves 34 6th August 2002 11:07 AM
Page generated in 0.09891 seconds (80.41% PHP - 19.59% MySQL) with 11 queries
