Seeking help about my 2A3 to 45 conversion
Old 12th June 2003, 07:58 AM   #11
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Originally posted by mig-ru
By the way, you might want to get rid of the grid resistor on the 45, just cuts out power being made by the preamp stage.
Hi Dmitry,
I'd like to know more about that! Why is required for a 45 and not on the 2A3 on the same circuit?
Please enlighten me
Old 12th June 2003, 09:49 AM   #12
bournville is offline bournville  United Kingdom
The use of a 'grid stopper' resistor before the input grid of the output valve is to help reduce the dangers of parasitic oscillation - ideally the resistor should be connected as close to the grid connection on the valveholder as possible. The effect on such a resistor on overall gain is negligible.
Is it necessary on your new circuit? If your 45 amp has a greater gain then it might be more susceptible to parasitic oscillations I suppose... You may find that it is not strictly necessary although many designers like to include these resistors to help ensure stability, as the cost is so small, both in physical cost and in loss of gain.
Old 13th June 2003, 12:32 AM   #13
many thanks for the excellent explanation.
cheers.
Old 13th June 2003, 01:28 AM   #14
mig-ru is offline mig-ru  Russian Federation
i stick to the "more is less" concept. less components in sound path, the better. so why not leave it out and see if oscillation develops, if so just stick the resistors in.
Old 14th June 2003, 02:05 AM   #15
Agree with you. I prefer KISS too...
Seeking help about my 2A3 to 45 conversionHide this!Advertise here!
Desparately seeking F3 PCB's!!! sandyhooker Pass Labs 9 25th June 2009 10:05 AM
Seeking opinions. AEIOU Full Range 4 10th June 2009 01:59 PM
Seeking DIY Writers enjoythemusic1 Everything Else 1 3rd July 2008 03:05 PM
Seeking speakers ape72 Swap Meet 2 5th November 2006 01:52 AM
