diyAudio Sponsor
Old 8th March 2010, 07:11 PM   #1
Default SE Output Tranny - Dumb Question
Can someone explain why this wouldn't work?
If a non-gapped transformer intended for single ended use were equipped with a third (tertiary) winding in addition to the normal primary and secondary, why couldn't a DC current in this winding be used to cancel out the magnetic field created by the bias current in the primary, thereby virtually eliminating core saturation due to DC current flow and increasing the output capability of the transformer. The only disadvantage I can see is some heat generation and the need for another DC power source.
What am I missing here? I just need somebody who knows more about this to point out where I'm going wrong. It seems like a much less expensive solution than increasing the core size and gapping and I'm sure it would be done if it worked.
Thanks.
Old 8th March 2010, 07:43 PM   #2
Yvesm is online now Yvesm  France
Yvesm's Avatar
Because the DC source will short the audio signal apearing on the tertiary winding.
Unless you make the DC source such that it has an hi impedance for audio frequencies.
For exemple applying it thru a large inductor with plenty of iron inside
Yves.
Old 8th March 2010, 07:54 PM   #3
It will work.
There are as you say a few drawbacks. you need the sam number of ampere turns as in the primary which will devote approx the same core widow area for compensation winding as for the primary.
You will loose primary inductance, increase leakage inductance and waste some extra power for a equal size core.
/Olof
Edit:
OK, thanks Yves I missed the the most severe point
I'm not allowed to do magic, union rules...
Old 8th March 2010, 07:57 PM   #4
Yves.
The tube plate would see a low impedance reflected through the tranny by the DC coil - that makes sense.
Great answer. It seems obvious now. Thanks.
I guess there's no free lunch.
Old 8th March 2010, 08:10 PM   #5
Arnulf is offline Arnulf  Europe
Alas, no free lunch. But there is an area (one I have yet to explore): parafeed connection. Solid state CCS isn't prohibitively expensive and neither is coupling capacitor, at least compared to the price of new, true SE, OPT.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 8th March 2010, 08:21 PM   #6
Steerpike's Avatar
Exactly what you describe was used in some Telefunken table radios. The compensation winding was used as a DC filter choke with a large electrolytic cap to make up an LC filter, from which the overall B+ and screen supply for the amplifier was derived.
When one such transformer failed, I suceeded in using a PP/CT transformer in its stead. Ultra high fidelity isn't a design feature in a shortwave table radio.
With a single-ended ungapped OPT, there is also the option of using the Philips' "series balanced output" configuration:
http://people.cs.uu.nl/gerard/FotoAl.../SerBalOut.htm
Steerpike's Toybox
Old 8th March 2010, 08:23 PM   #7
DougL is offline DougL  United States
I disagree. Since the CSS needs twice as much voltage for the same output on a transformer, you are basically pushing the cost into the power supply.
Not saying it isn't valid, but its probably not a big cost saving.
YMMV
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 8th March 2010, 08:32 PM   #8
Yvesm's Avatar
As Olof stated, it's DC amperes per turn that "premagnetize" the iron.
So you must use as few turns as possible on a large core with minimal gap to maintain a decent primary inductance
Incidently, this improves hi frequency response by reducing the leakage inductance wich increases as the square of the number of turns.
Simple SE: ???Dumb Tube Rectifier question??? BillEpstein Tubes / Valves 6 3rd May 2009 05:52 PM
Se Tranny used on Parafeed!!! Triod lover Tubes / Valves 11 3rd March 2007 04:06 AM
SE Output Transfromers Question ianc13 Tubes / Valves 3 23rd August 2006 11:05 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
really dumb question about SE 6bq5 operating point (triode) zobsky Tubes / Valves 5 10th April 2004 12:07 PM
Page generated in 0.09462 seconds (77.33% PHP - 22.67% MySQL) with 10 queries
