some help for a newbie
Old 28th December 2001, 05:34 AM   #1
JBL is offline JBL  Canada
JBL's Avatar
Send a message via ICQ to JBL
Default some help for a newbie
I'm not new to electronic but i want to start using tube for electronic. i have recently found some old tube and would like to use them for practice.
They was taken(wekk suposed to be) from an old radio and it was working. I check the tube and they seem to be good.
I would like to know what would be an easy and cheap way to make those little guy work. Also some of them must be some sort of rf or maybe something else so I would like some info on them if someone got time to lose on that.
The tube number are:
12ba6
12be6
12av6
the two others are unmarked.
tanx for any help.
Old 28th December 2001, 06:34 AM   #2
GRollins is offline GRollins  United States
Try www.triodeelectronics.com for datasheets on tubes online. He's also got a lot of circuits. One of them may get you moving in the direction you want to go.
Grey
Old 28th December 2001, 12:10 PM   #3
John S. is offline John S.
Those tubes aren't generally used for audio.If you want to learn about tube electronics,a good approach is to either build something from a kit or look for a working piece of gear and get a schematic for it.This way you can study a working circuit,which is pretty helpful.Doesn't have to be anything fancy.Could be something like an old PA amp or whatever.As long as it works OK. The 2 pieces that started me going were a Fisher 400 receiver and a Harman Kardon integrated amp.This is the best way if money is an issue.Search the tag sales and second hand shops. Eventually,you'll find something.It's a lot easier learning from something that works.
Old 28th December 2001, 11:02 PM   #4
JBL's Avatar
I see i checked them at the link provided and this is not satisfactory.
Does someone can give me a part number for a cheap but useable tube in audio.
Old 29th December 2001, 01:35 AM   #5
lilolee is offline lilolee
What is it you want to do?
If you go here http://www.duncanamps.co.uk/cgi-bin/tdsl3.exe/ you'll find all the info on your tube list plus schematics for more common tubes.
lilolee
Old 31st December 2001, 11:10 AM   #6
DNAgent is offline DNAgent
The two output tubes tubes that I would recommend to the first time audio builder would be the 6AQ5 and 6BM8. The 6AQ5 will work in any circuit that features the 6V6, and they are so plentiful and cheap that you can experiment with (near) reckless abandon. I would highly recommend the 6BM8 for the first timer simply because of the circuits involving this tube require so few parts. In addition, there are literally hundreds of web pages (most of them in either Japanese or Korean, luckily schematics are schematics no matter where you're from) dedicated to using the 6BM8 in audio. You could build a stereo power amp with only two 6BM8s. Good luck and welcome to the world of tube DIY.
Old 8th January 2002, 03:06 PM   #7
Thatch_Ear is offline Thatch_Ear  United States
Thatch_Ear's Avatar
You could build an integrated amp simply and cheaply with a EF86 and a 6BM8. Most of the cost will be in the transformers. A stereo integrated could be done with a 12AX7(or a number of other dual sided triodes) and 2 6BM8s. Use diodes for rectification and save money there.
Thatch
Old 8th January 2002, 08:05 PM   #8
Hmmmm, given the tubes you're listing, the other two are probably a 35W4 and a 50C5. The 35W4 is a half wave rectifier tube and the 50C5 is a power amp pentode (beam tetrode?)
It's easy to tell the 35W4 and 50C5 apart by looking at their internal structures. The 35W4 plate will be smaller than the 50C5 and "hug" the cathode more closely.
If you are motivated enough, you could probably build a mono power amp with the 35W4, 50C5, and the 12AV6 (hope you saved the output transformer). You won't need a power transformer, but you will need to drop the line voltage to the heaters 22 volts (assuming you're using 120VAC line) so use the appropriate dropping resistor. You won't need the two diodes in the 12AV6; these were used for the detector and AVC in the radio and won't be needed in the amplifier. I'm attaching the schematic for a radio that uses these tubes so you can study the amplifier portion and perhaps hack the design to make your amp. Good luck.
DNAgent
Old 8th January 2002, 08:23 PM   #9
paulb is offline paulb  Canada
Exclamation Dangerous circuit
You should not build an amplifier without using an isolating transformer of some kind. The schematic shown above is an example of the classic non-isolated radios that were built back in the days before transistors. This approach is fine for a radio or TV set that can be placed in an insulating box (wood or plastic), and does not need to connect to anything else. To connect to an external signal source you need to expose the internal "ground" as part of the signal input. There's a 50-50 chance this terminal could be the Hot side of the AC line and will electrocute somebody, probably you.
You can buy 120-to-120 volt isolating transformers for not too much money.
Old 9th January 2002, 02:22 AM   #10
JBL's Avatar
well i'm not really interested into power amp(not now). I'm more interested to make some guitar effect or some sort of tube effect unit that would add that warm touch.
some help for a newbieHide this!Advertise here!
newbie Q memphissound Multi-Way 7 17th August 2006 12:36 PM
Yet another newbie hell0un1verse Introductions 1 30th March 2006 06:31 PM
Newbie w/ sub ?'s toenail Multi-Way 2 8th March 2003 02:10 PM
Newbie needs serious sub help AcidRain Multi-Way 4 7th March 2003 08:07 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 11:49 PM
