| diyAudio Sponsor | ||
Hey all.
I'm currently "designing" an all C3g phono stage, and this is what I've cobbled together from various sources I've come across. It's somewhat similar to audiodesignguides phono4, but using ccs loaded C3gs. I was thinking about using CCS loaded d3a's, but figured the gain would be far to much. (I liked the transformer coupled design too, but figured $$$ ...) The C3g will be sitting at about 180V, biased at 18ma (seemed a nice, arbitary point, but I'm not married to it). As I've calculated, this would give me about 44db gain (0.005V input, 0.8V output), which may be a tad much, but I could easily tweak the rest of my setup to match. Any advice/suggestions to improve it ? I am kind of attached to the idea of using the C3g's (at least for the input tube). |
#2 |
Previously: Kuei Yang Wang
Well, triode wired the C3g is just a 417A kind triode, not bad, by any notes. But why not make the first stage a Pentode? As a pentode has a very high output impedance (think current source) you can use the RIAA EQ Network as anode load, so the common headroom penalties etc. from passive EQ disappear, despite the EQ being still passive. Who knows, using the second stage also as Pentode with a low Anode load might sound very good. Somehow I like to use German pentodes as such, where possible. Many old German pro audio preamplifiers use the combo of pentode input and triode wired pentode output and because of their outstanding sound quality are quite sought after. Ciao T |
#3 |
By using RIAA network as the anode load, do you mean using the 22k resistor as the load (rather than the CCS), and omitting it from the network ?
Though wouldn't using the pentode in pentode mode (:P) increase the gain quite a bit ? Though, from my (very limited) understanding of pentodes, I should be able to adjust the gain via the anode resistor, then recalculate the RIAA from there ... ... or something. |
#4 | ||
Ciao T |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Input stage idea | lumanauw | Solid State | 29 | 29th July 2005 02:20 PM |
| Page generated in 0.08107 seconds (77.91% PHP - 22.09% MySQL) with 11 queries |
