| diyAudio Sponsor | ||
For a headamp with high efficiency low ohm phones where no hum can be tolerated general rule is that one must buy the Tentlabs modules to use DHTs.
I know the standard solution are LM317 CCS's but these require capacitance on the output to avoid ascillations which defeats the purpose of a CCS. However given the low .25A current requirement of the 71A, how would a regulated supply feeding 5 10M45's in paralell be for a DHT supply? Anyone tried it? |
#2 |
What about the dn2540n-5 instead in the to-220 case it,s good for .5A
#3 |
Not as complicated as it looks: New DHT heater
#4 | |
#5 |
Not sure what you mean about the LM317. The datasheet doesn't show any output caps for a CCS. A discrete CCS with a few transistors should handle 250mA easily.
#6 | |
Sheldon |
#7 | |
I know it doesn't, but I spoken to several who have tried and all found high freq oscillation without caps on the output rails. Headphones are very sensitive and pick up things speaker guys never notice. |
#8 |
I guess thats my issue with the gyrator. PMillet has a DHT fillament design basically an LM1085 voltage regulating into a choke. Yet in his commercial DHT headamp he had to use something better for the DHT filament supply, some sort of very high freq oscillator. So I'm not sure the gyrator would have the performance I need based on this limited info.
#9 |
http://www.ecpaudio.com |
#10 |
Thankyou dsavitsk, I imagine with a separate PS chassis its best to put the CCS portion in the tube chassis?
| DHT bias and filament supply in one? | dsavitsk | Tubes / Valves | 7 | 10th July 2009 04:50 AM |
| Yet another DHT filament supply | astouffer | Tubes / Valves | 25 | 5th July 2009 11:08 PM |
| Filament Transformer for 26 DHT | korneluk | Tubes / Valves | 7 | 8th January 2008 06:25 PM |
| DHT filament PSU: What would you do? | Fuling | Tubes / Valves | 11 | 15th September 2007 09:18 AM |
| dht p-p filament question | enochRoot | Tubes / Valves | 7 | 25th September 2005 04:31 PM |
| Page generated in 0.09628 seconds (77.81% PHP - 22.19% MySQL) with 11 queries |
