| diyAudio Sponsor | ||
Repost from Digital Line:
I have picked up a Behringer SRC2496 after reading some positive stories online. It sounds horrible stock, but I am planning to build an SRPP output stage using subminiature tubes (6N16). Datasheet here: audio.ring.lt/pdf/6n16b.pdf Since this is my first tube project, I would like to run the setup by some more experienced people. SRPP B+ at 100V Rk = 333 Ohm Ra = 16k6 Ohm R to ground = 300 Ohm I still have some trouble designing the PSU, esp. wrt to the load resistance of the tube circuit. Thanks for the help! |
| PCM1742KE + tube output stage | Bem-bem | Digital Source | 1 | 4th June 2007 12:43 PM |
| Tube Output Stage | Mighty Mouse | Tubes / Valves | 3 | 24th August 2004 08:08 PM |
| Tube output stage for DAC | ackcheng | Tubes / Valves | 10 | 14th January 2004 12:13 PM |
| Tube output stage for DAC | ackcheng | Digital Source | 0 | 9th January 2004 05:03 PM |
| need help on tube output stage.. | tone | Digital Source | 2 | 19th March 2003 04:52 PM |
| Page generated in 0.06359 seconds (68.85% PHP - 31.15% MySQL) with 10 queries |
